Discseven's Avatar
Green Chain Tensioner O-rings
I'm changing my chain tensioner o-rings in a '85 3.2 and I have someone screeming at me not to use "the red seals!... USE ONLY GREEN! --- they last longer!"
Should I be listening to this screeming?!?!?!
I've dug around online for a while and red seals abound. Green... none.
What do you think!?!?!
Karl ~
Old 12-10-2012, 07:37 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Red seals are fine. They're silicone and quite durable. You can put a bit of o-ring lubricant on them like Dow 111, Dow 55, Sil-Glyde, or Permatex Disc Brake Caliper lube to protect the ring from oil contamination. They'll last a long time.
Kevin L
'86 Carrera "Larry"
Old 12-10-2012, 10:11 AM
i would rather use the green ones, but they don't seem to be available. when wrightwood racing says sorry, yer outta luck.
206 637 4071
Old 12-10-2012, 11:23 AM
KTL KTL is offline
Schleprock
KTL's Avatar
John,
If you have a new one handy, red or green, measure the dims of the ring and the tensioner and i'll see what I can find in bulk?
Kevin L
'86 Carrera "Larry"
Old 12-10-2012, 11:51 AM
Originally Posted by KTL View Post
John,
McMaster has Viton o-rings in pretty much every shape and size. So, you should be able to find them if you have a sample to measure.
I think I had a couple spares from my engine rebuild though. If you don't find the measurements by this weekend, I'll try to find them when I get home from LA.
Old 12-10-2012, 04:16 PM
