86FlatSix
JQ911's Avatar
Headlight hi/low beam issue - newbie
Hi,
I drove 120 miles over the weekend and on my way home around 1:30am, I noticed my low beam went hi-beam suddenly without me clicking the combination switch or stalk. For the remaining 50 miles, my lights were stuck on hi-beam, good thing it was past midnight so a few cars were on the freeway so I just had to be courteous enough not have somebody in front of me and drove at the rightmost lane so as not to antagonize the car approaching me once I exited the freeway.
Even if I click the switch/stalk nothing happens and the hi-beam indicator light is always on. Does this mean I have a busted relay or fuse on my low beam? If so, how come when I click the stalk nothing happens as it remains on hi-beam? It should have turned-off the lights if the fuse or relay is the question once I click the stalk from hi-beam to low beam?
I suspect my combination switch or the stalk may have shorted or something. I was checking on the fuse box but unfortunately, I don't have the relay diagram on the fuse box cover so I wouldn't know what fuse or relay to check.
74 BMW 2002 (rust rocket)
86 911 Coupe (weekend warrior)
09 997.2 C2 (semi-daily)
Old 08-27-2012, 10:09 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Stalk.
Originally Posted by JQ911 View Post
Hi,
Hope this helps:
turn signal switch quick fix pictures
Also, add relays.
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 08-27-2012, 10:19 AM
OsoMoore's Avatar
Common issue - lots of threads. I had it happen to me and I ended up taking off the steering wheel and putting a nice little shim into the switch to fix it. Don't shock yourself!
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Rebuilt and roaring to go!
Old 08-27-2012, 10:54 AM
86FlatSix
JQ911's Avatar
Originally Posted by 86 911 Targa View Post
Wow thanks Gerry! I now have something to do over the weekend. I got scared as I thought something went wrong with my electrical.
Old 08-27-2012, 11:01 AM
86FlatSix
JQ911's Avatar
You can just imagine how I was feeling when this thing happened at 1:30am. I was praying my lights won't give up on me on the freeway as I still had about 50 miles to go.
Old 08-27-2012, 11:04 AM
Dublinoh's Avatar
Search for threads covering relay installation...full voltage for lights goes through the switch in factory configuration...this contributes to degradation of the switch over time. This is a common upgrade and not expensive.
Old 08-27-2012, 11:08 AM
While your situation sounds like it was quite stressful, mine manifest itself in a very compromising way -- my high beams would flash and/or stay on whenever I used my turn signal. This caused quite a few folks to assume I was perpetuating the Porsche owners' negative stereotype
Old 08-27-2012, 11:18 AM
86FlatSix
JQ911's Avatar
I know the feeling specially when somebody is approaching. I can just imagine what the other guy thought of when I passed by with my hi-beams glaring him. I was just fortunate that it was 1:30am and a few cars were on the road and the lights did not give up on me which I was waiting for as I thought electrical gremlins are acting up. I always experience that in my Merc and I just thought not again.
Old 08-27-2012, 11:32 AM
Jwest headlight relays.
Here's more help.
After you clean/adjust the stalk switches.
Gerry
1986 911 Targa.
Only in L.A.:
Old 08-27-2012, 12:55 PM
On a happy note, if you were running your stock headlamps, they were not blinding anyone, as even on High-Beam, they don't come close to the more modern lamps in terms of brightness.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 08-27-2012, 12:59 PM
emac's Avatar
I did the same repair this weekend, took one half hour. Be sure to mark your steering wheel before you remove it. That way it will line up just as you had it before you pulled it.
Ernie 81 SC
Old 08-27-2012, 01:27 PM
ejp ejp is offline
ejp's Avatar
Ha! I just went through this. Was on the road in rural Maryland at 11 PM, an hour from my destination and 45 minutes from anywhere, really. First thought was fear of fire. Second thought was fear of losing my headlights that far from anywhere at 11 PM. Third thought was how it was a good thing that the headlights on my old 911 suck compared to modern ones, so the brights wouldn't bother anyone
In any case, I just installed a new stalk/switch this weekend. The job was fairly easy, but if I were to do it again, I would do it differently. I posted some suggestions/additions to the other instructions out there (e.g. how to use and not use the steering/ignition lock, scribing the wheel with chalk, and removing the headlight switch - the last part is important, and would have saved me a lot of time).
I haven't had a chance to install the relay kit yet...but it will the the next thing I do when I have some daylight time (parts are sitting on top of my toolbox). I just hope that I don't fry the stalk/switch again before I get around to the relay kit.
-Ethan
Old 08-27-2012, 01:47 PM
No sleep 'til... BROOKLYN
flatsixjunky's Avatar
Here's more help.
Gerry
Nice pics for installing the headlight relay's.
Now JQ911, go and install 100W headlight bulbs to melt those Lexus bumbers, GO, GO
Just kidding.
-Orlando-
'89 3.2L G-50
'77 S w '79, 3.0L
'90 T-3 Syncro
32C #16
Old 08-27-2012, 01:56 PM
porwolf's Avatar
I also fixed the turn signal switch on my 79SC recently. And it was a complete success. This is what did it for me:
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 08-27-2012, 02:49 PM
dshepp806's Avatar
Sometimes a good cleaning/burnishing/bending will do the trick!!!!!!!!!!!
BEST!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 08-27-2012, 03:42 PM
86FlatSix
JQ911's Avatar
The problem was I just upgraded from sugar scoops to H4s a month ago so my headlights were relatively new and it was somewhat bright. however, it does not compare to the new HIDs
Old 08-27-2012, 05:47 PM
86FlatSix
JQ911's Avatar
Thanks for all the tips! Will keep you posted over the weekend.
Old 08-27-2012, 05:51 PM
86FlatSix
JQ911's Avatar
Did the same procedure this morning and I hope this holds up. Apparently, the contacts are somewhat loose so I have to tweak and put a gap in between the two metal thin bars illustrated on top of the bar you straightened out. I got my low beam back and tried switching to hi beam with success. Will check tomorrow if the tweaking I did works.
Old 09-01-2012, 04:43 PM
