Front Jacking Point??
hello all..
I think I can hear the "Well DUUUH!"'s now, but here goes anyway.....: Is the circled area the appropriate jack point for a floor jack to lift the front end to place axle stands under the torsion bar ends? It looks like it is and has been used previously but I wanted to be sure... ![]() (PS Gerry if you read this, the motor is FA coming off this week.....)
Neil 1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic (X) [B] 2011 BMW X5[B] 'Success is not final, failure is not fatal. It is the courage to continue that counts' |
Warren Hall Student
That's what it's there for.
Go for it.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
Yes, that is a jack point.
This post gives you the full skinny: Quote:
Thanks fellas.....I knew the duuhs were on me.......
Not to worry. No dumb questions. Be safe.
Interesting to note, my early cars don't have that reinforced "cube" jack point--just the seam. Does anyone know when the reinforcement started? Was it with the impact bumper cars in 74, or sometime later?
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
Ubi bene ibi patria
Cheers & I hope this doesn't constitute a thread hi-jack. JB |
Not at all Hawkeye.....we're all here to share our knowledge and learn from others....go right ahead and get the information.
You never know, I may buy an older car also and will need to know.... Neil
1980 911 SC
My 80 SC is minus the "cube" as well.
I took a 4"X4"X2" and carefully traced the seem on the block and then took a router to it. The seem passes thru the groove made with the router without the weight of the car putting any pressure on it. The block sits directly on the jack stand. ![]() Please excuse the rust! It's all been taken care of. Sat like that for 6 months.
Life's a Beach Last edited by sailchef; 04-27-2010 at 05:08 PM.. |
Andy Bullen
Good afternoon gentlemen, I'm part of the cube-less crowd as well. The seam tracing block idea is brilliant! My only question is - where do you actually lift the car until you place the jackstand there?
76 912E - Grocery Getter 04 Toyota TacomaTRD - Beater Truck 08 Honda OdysseyEXL - Family Hauler |
Banned
I lift at the factory point right aft of the door. Using the Pelican jack pad and my floor jack. |
ps: If the wheels come off the car...they go UNDER the tub as Sailchief has in his picture above. Don't trust your life on jacktands alone. Also, when jacking one side, then the other, if you're going very high, do it in more than a single step...don't want it to topple off the stands. BE SAFE!!! Last edited by KFC911; 09-02-2012 at 02:30 PM.. |
Andy Bullen
Thank you gentlemen, I think I have what I need....
Banned
