I have re-ringed many alusil motors (some for racing).
james www.gruppe9autowerks.com Its not how fast you go...its how you go fast |
Fleabit peanut monkey
I did not have to re-ring mine as the end gaps were well within tolerance. Although, top end rebuild was premature because of head stud failure.
1981 911SC Targa Last edited by Bob Kontak; 09-07-2012 at 05:59 AM.. |
I have an '83 small port CIS motor and went from the 9.3 USA pistons to the euro 9.8's... also with 964 cams.
Dont be tempted to run too much timing. I have detonated pistons getting too froggy with advance, the car just feels great until smoke bellows out the tailpipe. ![]() I ran the same CIS without any changes for years, however I have Webers now.
-Vinny 1983 911SC Last edited by Vin-barrett; 09-07-2012 at 06:14 AM.. |
With all the potential problems with the increased 9.8:1 c/r, for the minimal gain it seems to give, it no longer seems to be worth it to me.
So, I think I've been convinced not to change the pistons/cylinders at all and reuse my existing 9.3:1 alusil ones. It seems alot of people have gone this route with good success, including some reputible shops. In fact below is Ollie's response to me in this regard: Hi Matt, We've been using Sunnen equipment for many years now that has a process to handle Alusil honing. Please give us a call and we can discuss the process with you - ask for George. Ike Plus this seems to make my engine rebuild budget much more managable. Thank you all for the info, especially the ones who provided the additional info on PM's.
Matt. 83 911SC 85.5 944 NA - Sold |
good info from Ollie's, I'd love to know what they charge to process Alusils
Looking forward to hearing how your rebuild turns out
-Vinny 1983 911SC |
The price list on their website shows $ 45/cylinder.
End gaps are not the only reason to re-ring. Cylinders don't wear evenly and a ring will "learn" its place and wear unevenly with the cylinder. Once you take the piston out of the cylinder its impossible to reinstall it back in the same place and this could lead to sealing issues. Its usually not that big a deal on a street motor but if your looking for every last HP you'd be leaving a few on the table.
Unanswered in all this is the question of how much benefit the Euro 9.8s will give over the US 9.3s if you don't run the big port heads and runners.
It seems pretty obvious that you will pick up a bit of power, but not as much as the Euro motors, right? When the US motors switched to the smaller intake ports and runners in '80, the Euros kept their setup as it was. And when they went to the 9.8/1 with the big ports, they got the advantages which made them able to run with the 3.2s. On the other hand, bumping the CR from 8.5 to 9.3, but making the ports smaller on the US motors ended up with the HP basically the same. Me, I would not go out of my way financially to switch to the 9.8/1 if I wasn't also going to the big ports and runners. All moot for me, though, as I run my '82 SC in a stock engine class. All I did when I rebuilt it was buy a new set of Nikasil Mahles to replace the Alusils. |
1981 911SC Targa |
