Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
Question Odometer question?
Noticed today that after I filled up and reset the trip odometer yesterday it is showing that I have not driven an single mile! What could cause this...it was working until then?
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 06-01-2002, 11:54 AM
If you pushed the reset button while the car was moving you may have stripped an odometer gear or broken a gear attachment to a shaft. If this is the case a repair will be in order; it can be a DIY job if you can obtain the gear but the VDO company apparently makes it difficult for the DIY person to obtain one. Sometimes a gear will apparently just loosen on a shaft (plastic expands or cracks due to time and heat?) and slip and the odometer will stop logging. This happened to me last summer in my '76 during a very hot crossing of Wyoming. The odomter stopped logging for about 30 miles then resumed and has worked ever since. The speedometer/odometer repairs can be done by various companies; I believe Pelican can arrange such repairs. Probably at least a $100 with a speedometer calibration. Jim
Old 06-01-2002, 01:58 PM
Montana 911
k9handler's Avatar
thanks, I did it while moving so I prabably broke it.
H.D. Smith
2020 Yamaha YFZ450R
Old 06-01-2002, 03:27 PM
