Vacuum Leak
Hi-
I've been reading posts about taking the cover off your oil fill tube and if the car idles the same you have a vacuum leak. I pulled the cap off and nothing changed with the idle and looked around for loose connector, but can anyone point me to common vacuum leak areas?
Carl
Old 10-12-2012, 04:22 PM
aerodyn930's Avatar
Hi Carl, Need the year and model to comment on your findings,
Lou
Old 10-12-2012, 04:30 PM
Sorry,,,1989 911 Carerra.
Old 10-12-2012, 05:40 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Originally Posted by 86 911 Targa View Post
Have a look at these:
And this:
Also, use a smoke machine, or spray/mist starter fluid or propane near the suspicious areas.
If the idle increases, you found your leak!
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 10-12-2012, 05:48 PM
i have a 85 3.2, been chasing a vacuum leak for a while now. i replaced the 2 hoses, 1, the crankcase to oil tank and 2 throttle body to oil tank. didnt really solve the problem. now when i have the car running, and take off the oil cap the car stalls. any idea where i have the leak
Old 10-12-2012, 06:06 PM
aerodyn930's Avatar
Great photos of typical vaccum leaks ! For additional leaks check your intake manifold hold down nuts, Soak them with penetrant, Back them up 1/4 turn then re-torque, Very common on 3.2 carreras,
Hope this helps, Lou
Old 10-12-2012, 06:14 PM
Member 911 Anonymous
DRACO A5OG's Avatar
+ what Dr Gerry wrote.
I saw this on YouTube, a fella used a cigar and blew into one of the vacuum hoses to find his leak. Have not tried it but I did have my wrench use a smoke machine to find a torn "U" hose like the one in his 1st pic.
Jim
'85 Carrera Targa
PCA/POC
Old 10-13-2012, 06:20 PM
db_cooper's Avatar
Those intake nuts should be re-torqued every 15k or so. Even with care, the 3.2 engines like to suck the gaskets..very notorious leakers.
Old 10-14-2012, 10:23 AM
