I'd go with the MFI. Even in a non-standard set up they can work very well. I have MFI on my 2.5l (short stroke), using TWM throttle bodies and it just screems!
------------------ Mike See my cars |
Thanks all for your input. At this point I'll stick with the MFI and see how they perform. I've ordered a dual in/dual out dansk to see how that performs. Other that obvious stumbling or rough idle symptoms, how will I know if I need to "tweak" the MFI to get the most out of my planned 10.5 CR and twin plug setup? Or can I hope for a bolt on and go setup? Ha ha ha. My last bolt on and go was my BK harness guide bar. I had to cut off 1" to make the bar fit into my early 911.
Thanks again everyone. This list is great! Regards, Rick |
KAT....I have no background on your set-up, but I would take the sensitivity of the 911 seriously, unless there is a bulletproof program to follow. In MHO I would install a exhaust temp. sender immediately, before expermenting with dialing in the beast. Don't let your meat loaf........Ron
DAVID......I took notice that you had a 2.7 w/E-cam, Webers, etc. I plan on that in my 2.7. Carbs are in closet, cams as soon as smog is over with. My 911 is 77 w/stock gearing. Question, how was torque on highway from 3000 to 4200 rpm? Did it burn clean, or dirty spark plugs. What spark plugs did you use? How long did plugs last? I'm looking for performance on cross-country rides...........Ron
Ron,
You can't use the 2.7 CIS pistons with 'E' or Solex cams ('E' engines used two different cams over the life of the three different production engines -- 2.0, 2.2, and 2.4) ... because of the lift, and not enough clearance with those funny 'humped' CIS pistons! So, you are faced with either getting aftermarket pistons like JE with valve clearance notch option, or the 'Euro' RS 2.7 piston & cylinder sets. For the money, if yours are Nikasil cylinders already, the JE 9.5:1 forged pistons are the way to go. Personally, I would recommend the GE-60 cams with a 2.7 Weber conversion, but the Solex cams are great, too, as Jack McAllister will testify ... Ferocious above 5000 rpm!!! And, with forged pistons ... 7300 rpm redline with either cam choice! ------------------ Warren Hall 1973 911S Targa 1992 Dodge Dakota 5.2 4X4 parts hauler |
Guest
Posts: n/a
maybe it would be a good idea to start with the "stock" heat exchanger and Leistritz muffler setup. at least you know you are starting with a known baseline. it's just i know of at least 1 person that after exhausting much time and effort ended up with the stock Leistritz muffler.
------------------ Carlo http://bigblue111c.tripod.com/dec2000/ |
