break fix drive repeat
Question about clutch engagement friction point
My dad and I spent some QT with my new to me 84 carrera this weekend:
Question 1: the clutch engages almost right off the pedalboard stop now. Is this normal? Before the all the work, it was engaging probably 2" off the stop. Overall the car is shifting significantly better -- it doesn't balk going into first from a stop anymore. Question 2: I still get a small chunk going into reverse when the trans is cold, seems to go right in when warm. Should I adjust the pedal stop even further back (maybe not getting full disengagement)? I'm at the upper end of the spec in the Bentley manual. thanks all Rich Last edited by rwilner; 09-09-2012 at 03:17 PM.. |
Recreational Mechanic
Your pedal travels should be 25mm total measured at the clutch arm. This is what you adjust by moving the stopper on the floorboard. No need for it to be any further if the cable is properly adjusted. Are you sure you had the cable housing stop on the new cable seated all the way in at the firewall? Sometimes if you don't get it seated completely, then adjust it to spec, it will seat the first couple presses of the pedal then you will be off. This would cause the symptoms you describe. As for reverse, Remember, it's a 915 transmission. It will shift like a tractor even when everything is optomized. After 12 years of tinkering with mine I learned just to lower my expectations. Regardless it sounds like your clutch is not adjusted properly at all, assuming everything is OK inside the bell housing.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing Last edited by Nickshu; 09-09-2012 at 03:47 PM.. |
I'll remeasure and try again. |
Just to close the loop here --
I had the clutch cable routed incorrectly under the car. I routed it correctly and adjusted per bently, shifting great now! Or, as great as a 915 can shift.... |
Many things about our P cars are very unlike Hondas. That's why we drive them!
I love my 915.
'81 924 , '85 944 , '78 911SC , '82 928 5.0L "They run best being run close to the ‘limit’ and done so regularly" - Grady |
