Non Compos Mentis
Hey, Big Motor Guys
Guys who have swapped big engines into early cars- What have you done with the oil thermostat and cooler lines to be able to fit 10" wheels with the 275's in the rear under carrera flares?
Old 06-05-2002, 09:08 AM
There is a picture here oil lines
Old 06-05-2002, 09:26 AM
Administrator
Jack Olsen's Avatar
We had to re-route one oil line higher and around. The two bolts on the spring plate also needed to get machined down.
After that, it's all about grinding the fender lip down and lots of negative camber.
Old 06-05-2002, 09:49 AM
Bill Verburg's Avatar
That oil line link goes a picture on my Porsche Owners Gallery page(Thanks again for such a great service Old Skull!!)
Here is an annotated version
The oil line fastener was relocated to fit in the shelf better at D, the nuts were ground down at E, its a very tight fit, not as difficult to achieve as at the front.
Bill Verburg
Old 06-05-2002, 01:34 PM
