Stuck Fuel Level Gauge After Fill-up
My fuel gauge seems to be getting stuck on E for an increasing length of time (miles) after I fill up the tank. At first it would stay empty for some seconds and spring up to F (4/4). After that, it will correctly indicate the fuel level as it is used up. But now, it took 2 days for it to indicate correctly after filling the tank. Does this look like a bad gauge itself or is it some kind of sensor inside the tank that is stuck or going bad?
Arnie Diaz Braselton, GA ------------- 1982 911 SC (3.2), Fabspeed Bypass and Muffler 2003 E39 BMW 530i (Daily Driver) |
The sender float is sticking. It is real easy on a 911 to get it out. I would wait until in is low on fuel and remove the sender. It is right on top of the tank. You will see where it is catching. Mine was an easy fix.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
JUst pull your float, very easy from the top of the tank, they tend to gum up. Easier just to replace it, get a new seal while you're at it.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
The sender in the tank is sticking or the wiring is broken. To check: lift up the carpet in the trunk you'll see a round plate with a pair of wires turn your key on and ground the center wire while watching the gauge. It should 4/4 with wire disconnected when grounded should read empty. If that test is OK then the sender itself is getting stuck. remove inspect and clean. Look in the tank with a flashlight to inspect for rust.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Thanks guys, I'll check it this weekend and report back...
Mo money = mo parts
I replaced mine when I thought the problem was the sender, turned out to be the gauge itself. My symptoms were different, needle would just drop like it there was no power. I still have it. New ones are $120. I'll make you a deal if it turns out you need one. PM me if interested.
Greg 86 Coupe (stock - pretty much like Butzi designed it) 65 Ducati Monza 250 & 66 Monza Junior (project) "if you are lucky enough to own a Porsche, you are lucky enough" |
Undocumented User
I fixed mine recently after the sender stopped working. It turned out that during an autocross spin, the cylindrical part of the gauge shifted and would not move from 1/2. I took it apart as described, cleaned everything, made sure the float moved freely and easily, tightened up the electrical contacts that ride one the guide wires and it's been perfect once again. I would make sure that when you put it back together that you pay attention to the way the cap sits on the aluminum cylinder and that you crimp it a little into the plastic to prevent it from easily coming apart again.
Twenty minute repair, just do it when your tank is low to avoid messes, and do it in a well ventilated area! |
Just replaced mine, as well,....it was quite intermittent. I installed a new one (she had the original 23 year old one),..and tucked the old away to refurb later. I'm betting that the old one is repairable, after a nice clean-up,....but will still be relegated to the "original parts stock bin". Fuel level readouts are now accurate and much smoother.
It was "time"... BEST! Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
ROW '78 911 Targa
Bottom plastic piece fell off mine causing the outer housing to bind on float. Round pill bottle cap, washer and nut fixed it right up
Just dissassembled my old one and cleaned it up considerably,..I may reinstall it to make sure that the travel is clean (as it now appears to be),..keep it as stock (still).
BEST! Doyle
