'81 ROW SC Charcoal Canister
Found the NLA strap that secures the charcoal canister in front of the oil tank but not sure what it attaches to? I ordered the slotted machine screw from Porsche along with the washer and nut and as far as I can tell the strap wraps around the canister, but I don't see anything on the body to attach the strap to. Does the canister just lodge in there?
Would appreciate a photo of an original setup for guidance.
Thanks.
Old 09-17-2012, 10:23 AM
PhD on Pending Projects
wachuko's Avatar
Send a message via AIM to wachuko Send a message via Yahoo to wachuko
Thanks.
Bad photo, but gives you the idea of where it goes...
Drive safe!
1967 - Porsche 912
1981 - Porsche 911 SC
1991 - Porsche 911 C4 Wide-body Cabriolet
Old 09-17-2012, 11:08 AM
Thanks, but the canister is located in the passenger rear on an '81 911...
Old 09-17-2012, 11:29 AM
wachuko's Avatar
Cool
Ah... that was on my '83... one sec, I have an '81 on the lift. Let me take a look...
Drive safe!
1967 - Porsche 912
Old 09-17-2012, 11:41 AM
Thanks. The strap has holes in the flanges at either end to accept the screw. I can't tell if the screw is supposed to thread into the body, or does the screw help cinch the strap and canister around something?
Old 09-17-2012, 11:51 AM
wachuko's Avatar
Hummm... on the passenger side, this is the only thing that is there... a single bracket with nothing attached... I just got this car, so looks like I can't be of much help. Someone else will have to chime in.
Drive safe!
1967 - Porsche 912
Old 09-17-2012, 12:13 PM
wachuko's Avatar
What I meant to say... is that in the rear wheel area, I saw nothing that looked like it would hold something...
Here is the rear wheel well, passenger side (and there is nothing but the oil tank on the other side... sorry.
Drive safe!
1967 - Porsche 912
Old 09-17-2012, 12:49 PM
Porchcar guy's Avatar
If I am correct.....It lies behind the oil fill pipe in the upper right side of the engine compartment...with you facing the engine .....at least on my 79SC.
15 year PCA member
1972 911 E Coupe - gone now
1987 Mazda RX-7 2+2 - still cooking
Swift DB-1 FF & Swift DB-3 F2000 -not forgotten
1979 911SC 3.0 & 2000 Camaro
Old 09-17-2012, 01:03 PM
wachuko's Avatar
Cool
There it is... let me see if I can take a better photo..
Drive safe!
1967 - Porsche 912
Old 09-17-2012, 01:09 PM
wachuko's Avatar
Give me an hour and I will remove it and take photos of what is behind it and how it is held in place.
Drive safe!
1967 - Porsche 912
Old 09-17-2012, 01:18 PM
That was my assumption. Its located above the engine tin, not below in the wheel well...
Old 09-17-2012, 01:27 PM
wachuko's Avatar
Porsche Crest
I need to remove the engine and would be no problem to remove the canister and take photos... will do so in about an hour so you can see what is behind it.
Drive safe!
1967 - Porsche 912
Old 09-17-2012, 01:37 PM
wachuko's Avatar
Cool
Spot welded in place... pretty sure you can use the same epoxy used to glue the door skins and avoid welding...
Drive safe!
1967 - Porsche 912
Old 09-17-2012, 06:04 PM
Thanks Wachuko! I really appreciate the effort! That explains the lack of a hole in the strap.
Old 09-18-2012, 06:21 AM
