<insert witty title here>
Christien's Avatar
Oil leak pooling in heat exchanger, catching fire
Something is leaking onto and into the driver'a side heat exchanger, and the oil is catching fire when the exhaust gets hot. I replaced the oil return tubes (1 was definitely leaking) and tightened the valve cover nuts a tiny bit (half turn each). I can't think of anything else than can be dripping on there. Any thoughts?
Today I did a "controlled burn" to try to clear out the remaining oil. Have a look. It's been burning for almost 15 minutes now!
Heat exchanger oil fire - YouTube
Old 04-23-2013, 11:03 AM
emac's Avatar
Christine replace the v/c gaskets with the silicone style I had the same issue. I washed my oil off didn't have the balls to do a controlled burn. Lol
Ernie 81sc
Old 04-23-2013, 11:21 AM
Christien's Avatar
Already have the silicone gaskets. I can't wash the oil off because it's inside the heat exchanger.
Current: 1987 911 cabrio
Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster
Old 04-23-2013, 11:31 AM
Christien's Avatar
It burned for over 30 minutes, until I finally splashed some water on it to put it out.
Old 04-23-2013, 11:32 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Drill a .040 hole at the low spot. Or remove the air hoses in the engine compartment and run a hose with water into the heat exchanger, the oil will float out around the holes you can see fire through. The "controlled burn" is without a doubt the dumbest thing you can do, burning petroleum with a high cubic foot fan on the frontside is a recipe for disaster. Up your insurance on the car and house to the max, you will need it eventually.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 04-23-2013, 11:37 AM
Christien's Avatar
Good idea. The car wasn't running when I was burning it off - I hit it with a blowtorch, and the fire extinguisher was right beside me.
Old 04-23-2013, 11:42 AM
Christien's Avatar
I think I got it taken care of. I hit it with some degreaser, let it sit a while, then flushed it with lots of water. Fired the car up for the first time this season and let it run for about 20 minutes. The smoke gradually diminished, and no flame. When I shut it off, it was still sizzling inside the heater box like a bbq!
Heat exchanger bbq - YouTube
Old 04-23-2013, 02:20 PM
ROW '78 911 Targa
timmy2's Avatar
Have you found and stopped the leak?
You'll be back doing it again if not.
Old 04-23-2013, 02:34 PM
fastfredracing's Avatar
Any leakage at the rocker shaft areas?
No left turn un stoned
Old 04-23-2013, 02:50 PM
Kirk911SC's Avatar
Cam towers leaking?
I had oil dripping on my exhaust in the 930 and it would smoke. Nothing quite likes yours though!!
Your heater is going to smell reeeeal nice!
- '00 Dodge Viper GTS - Steel Grey - Yep...a domestic.
- '87 930 - Guards Red - Sold
- '82 911SC - Grand Prix White - Gone
- '78 928 - Silver - Long gone
- '04 Subaru WRX wagon - Sold
Old 04-23-2013, 02:59 PM
Christien's Avatar
Once it's cool I'm going to put some paper over top of the heat exchanger to see if there's any fresh leakage.
Old 04-23-2013, 03:01 PM
ROW '78 911 Targa
timmy2's Avatar
If it is the rocker shaft(s) or cam tower it won't leak unless it is running. Ask me how I know!
Old 04-23-2013, 03:35 PM
Christien's Avatar
I'm about 90% certain it was leaking while not running, because the big oil buildup leading to flames only happened after the car had sat for a few days. It happened twice last fall, but not when it was being driven regularly, at least once a day. That leads me to believe that it was leaking while sitting, and if it was just a small amount (like overnight) it would burn off as smoke the next day.
Old 04-23-2013, 03:43 PM
Senior Advisor
James Brown's Avatar
remember all that smoke/crap will go in the cabin with the heat on.
08 Cayenne Turbo
Old 04-23-2013, 07:37 PM
Christien's Avatar
Yesterday evening I put some paper on top of the heat exchanger, and this morning it was 100% clean, not a drop of oil - good news!
Old 04-24-2013, 05:40 AM
