Measuring accurate ET of wheel?
Does anyone know of an accurate way of measuring the ET of a wheel?
Many thanks,
Dan
Old 09-27-2012, 10:23 AM
Bill Verburg's Avatar
Many thanks,
Dan
Accuracy will depend on the tools and skills of the measureer
the formula is
ET = backspace - .5*overall width
I use stiff lath that lays across the flanges then measure to the mounting face w/ a micrometer
error comes from parallax and deflection but you will be very close to actual if you are careful
Bill Verburg
Old 09-27-2012, 10:37 AM
Thanks Bill, this what I have for measurements:
17 x 8.5 with a backspace of 6 inches
17 x 10 with a backspace of 7.5 inches
Trying to figure what the ET's are for each wheel?
Dan
Old 09-27-2012, 10:56 AM
Rescuer of old cars
Arne2's Avatar
Dan
Rim width is to the bead seats. To measure offset accurately, you need to measure the overall width of the entire wheel, which can't be done while tires are mounted.
The offset on many modern wheels will be stamped or cast into the wheel somewhere. Look for something like "ETxx" or "etxx".
For an approximation (generally good to ± 3mm or so), we can assume that the overall width of the wheel is approximately 1" more than the bead seat width. So the 17x8.5 is probably 9.5" overall, and the 10" is probably 11". This gives:
Front
6 - (9.5/2) = 1.25" or approx. 32mm
Rear
7.5 - (11/2) = 2" or approx. 51mm
Does this help?
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 09-27-2012, 11:23 AM
it can w/ lathe of the proper length, here I have one on each side so that overall width can be measured
often, but not always
again, often, but not always. Notable exceptions are Fuchs and BBS
Bill Verburg
Old 09-27-2012, 11:37 AM
I very much appreciate you guys taking the time to go into detail on this. The only thing that has me confused is what you come out with a front wheel ET. This is for a set of Fikse 993 fitment that I'm selling. I would have thought the ET's would have been closer to the high 40's for a 8.5 front rim?
Dan
Old 09-27-2012, 01:32 PM
Dan
Glad to help but you still have not specified what the 8.5 or 10 measure, is that bead width or overall width?
people usually talk about bead width but overall is what is needed
Bill Verburg
Old 09-27-2012, 01:36 PM
KTL KTL is offline
Schleprock
KTL's Avatar
If you're trying to push the limits of what your body or suspension will allow, you certainly want to be accurate. Bill's method accomplishes that with stiff pieces of wood that span the rim edges. It's critical to use the rim edges IMO because often times a "stretched" tire installation can have the rim edges protruding past the tire sidewall. Therefore the rim edge is a critical clearance.
Measure the rim width from edge-to-edge. Divide that in half.
Then measure down to the wheel hub/mounting surface from your stiff straightedge laid across the wheel. This is the backspacing. Subtract the backspacing from the 1/2 rim width and there's your offset.
Kevin L
'86 Carrera "Larry"
Old 09-27-2012, 01:43 PM
OK, what I need to do is remeasure the overall width since the tires are mounted as indicated by Bill's picture. I'll do that this evening.
Can't thank you enough for your help guys,
Dan
Old 09-27-2012, 02:13 PM
