How do you install an SC front valence?
Thanks in advance for any help received. There is a volume of information regarding rubber lip spoiler installation both on line and in books....can't find anything that describes valence installation! There 8 mounting points: 2 on each side mounting the valence to the metal shroud behind the rubber accordian, 1 on each side mounting a metal tab on the valence to the front bumber and finally 2 bolts that thread through tabs on the front of the valence into threaded mounting points in the front trunk. Any help from someone that has done this installation would be appreciated. My thought process was to start from the sides and work towards the 2 in the middle, having done that, I see no way to start the 2 bolts in the middle..... Thanks
Marvin
1986 944 Racecar
2000 Boxster ClubSport
Old 09-23-2012, 12:00 PM
Chief Head Scratcher
kerthunk's Avatar
On my '79 there are clip-on nuts that go onto the valence and then screws that you put in from the trunk side into the valence.
John Morris
'79 911SC
Old 09-23-2012, 12:15 PM
Well that makes a lot of damn sense!! Where are the bolts in the trunk?
Marvin
1986 944 Racecar
Old 09-23-2012, 12:20 PM
Found them....I owe you a cold beer!
1986 944 Racecar
Old 09-23-2012, 12:28 PM
Cooper911SC's Avatar
Yep, I hang the valance from the two screws inside the trunk first, loosely.
Next work on each side, and finally snug everything up.
Old 09-23-2012, 04:16 PM
Done!
Thanks to everyones help! Job done.....test drive complete....grill fired....cold beer in hand!
1986 944 Racecar
Old 09-23-2012, 04:47 PM
kerthunk's Avatar
Looks great!
BTW, my cold beer hasn't shown up yet...you better not be drinking mine!!!
John Morris
'79 911SC
Old 09-23-2012, 05:46 PM
