Sanity check on susp setup quote?
Alignment, lower ride height to European spec, and corner balance.
What's a reasonable number of hours for that from a reputable shop?
Old 09-24-2012, 01:53 PM
I had mine done last week. The shop quoted 4.5 hours for the job. However, we discovered that my car had a bend trailing arm on the rear left and this was the reason for the tire wear. So they installed a used trailing arm. The bill itemized still 4.5 hours for the ride height adjustment, alignment and corner balancing.
'86 Carrera Cabriolet Grand Prix White
'09 VW Beetle Convertible
‘24 Audi Q8 etron
Old 09-24-2012, 06:12 PM
Thanks for the reply. I was quoted 8 and it doesn't sit right with me.
Anyone else?
Ken
1986 930 2016 R1200RS
Old 09-25-2012, 06:31 AM
Senior Member
Eight hours with no repair sure seems like far too much. Course everything in Westchester County costs more...
Old 09-25-2012, 06:58 AM
Just had mine done a couple months ago. It was ~$430 if I recall.
Old 09-25-2012, 07:36 AM
Having mine done tomorrow... $350 for said work. (Plus another who knows what for the replacement front crossmember and rear eccentric bolt that were damaged and needing replacement)
'87 911 Carrera Coupe (go fast, small parts / small kids hauler)
'04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius")
Old 09-25-2012, 07:47 AM
white rabbit
Send a message via Yahoo to Don LaVance
Just had mine done on my 88 Carrera in the SF Bay area. Also had new trailing arm bushings installed at that time. Also had my car raised to Euro standards, (Yes raised up to that).
Labor on the raising, alignment and corner balancing was 4.0 hrs.
Bushing removal/installation labor quote was 5.50 hrs. Excellent results and work quality.
About $1,200 in all parts and labor.
Old 09-25-2012, 08:12 AM
one of gods prototypes
bell's Avatar
it mostly depends on if the rear t bars need reindexed, if so then it's not out of line if changing bushings etc.....
Brought to you by Carl's Jr.
Old 09-25-2012, 08:29 AM
Thanks for the replies.
I'm not too familiar with the rear setup, but I know the front uses a bolt to raise or lower within some range before t-bars need to be reclocked.
If I lowered the car, am I saving myself anything? I understand from searches it's a PITA, but is that half of the labor? Or does the corner balance entail rear bars out anyway, so I gain nothing?
Ken
Old 09-25-2012, 08:53 AM
If you just want to have it corner balanced, then there should be enough adjustment in the spring plates. Adjusting the ride height significantly may require re-setting the torsion bars and at that time the job becomes much more involved.
‘24 Audi Q8 etron
Old 09-25-2012, 10:38 AM
Porsche made the rear spring plates adjustable but they installed them in such as way as to require a re-indexing of the bars to achieve any serious reduction in height. So, if the shop hasn't seen your car, or if they are unsure whether they will have to re-index the bars to lower the car the amount you want, I'd say the labor estimate is not unreasonable. Not all cars are the same, some take a lot longer than others. Ever consider asking them what's included and what they expect?
JR
Old 09-25-2012, 11:35 AM
Jmorski's Avatar
Just had mine done, lowered, added some camber all the way around, corner balanced, replaced some bushings, bigger rear torsion bars and front sway bar to balance it out, rolled fender lips. A lot of work to achieve the results I was after. All in $1600, worth every penny to have a pro do this work who will tune in the changes and adjust to balance out oversteer/understeer.
Current Project - http://forums.pelicanparts.com/paint-bodywork-discussion-forum/860107-mid-year-humane-society-76-re-fresh-4.html
PCA Member, Early S Reg member, 356 Reg member. Instagram Jason Morski
Current Rides: 76 911s 3.4 white/lobster hot rod, 2000 Boxster S Lapis Blue, 2005 Carrera S Riviera blue/pccb's, 13 Cayenne S, 2018 GT3 Lava Orange
Old 09-25-2012, 03:34 PM
