Finally, 911 will not start!
Did not start a couple of times but will push start easy. I had battery checked (8 years old) and it was bad. Replaced with new 85 month interstate battery and car will not start. I hear fuel pump and a click at the starter when I turn the key. Do you think a bad starter? Car will push start every time. tell me what you think please. Thanks, Nick
Fresh battery.......
Nick,
You replaced your 8-year battery with another 7-year year battery? Have the battery tested for voltage and crank amperage. The second battery could be another candidate for disposal. If your car could easily start by pushing, go find another good strong battery. That should solve your problem. Otherwise, have the starter inspected too. Keep us posted. Tony |
Sorry I replaced an old 85 month battery with a new 85 month battery. The old one was way past due but did a good job.
I think it probably is the starter because about a year ago it would not start on a trip so I push started it and when I got home I hit the starter with a rawhide mallet and it started well for a year. I just think that the starter and the battery gave up the ghost at the same time. $104.00 at Autozone! For a nice rebuilt unit.
new batteries sometimes need to be charged up first. or it could be a bad one. did you try jump starting it?
82 SC , 72 914 Last edited by porsche930dude; 09-25-2012 at 06:41 PM.. |
Clean the battery to chassis ground and also the trans. to body ground strap.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Hey, I tried to jump start it when I brought it home. Did not work. so I put a trickle charge on it for two hours and it just started right up!!!!!!! I bought it from a little Mex shop that sells new and used batteries in a poor part of town. It could have sat in the shop for a year! I know it is new because I see the interstate truck there all the time. And I could tell it was new. Anyway the battery was $110 out the door. We will see tomorrow if it is a good one! Nick
RETIRED
Give the solenoid a good whack.....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
most autoparts shops can test the start after you pull it out, it has saved my butt on one occasion on my Saab when the ground cable was actually the culprit, wasn't fully grounding.
____________________ 1985 Carrera: Big Reds = Ass Saver |
muck-raker
if you still have the Bosch starter, and the solenoid can be gently rapped into starting, it is probably time to start saving up for a new high torque starter.
This might be a good time to clean up those main grounding points, like Pete3799 pointed out. You could solve your issues with zero money and a little elbow grease. Also....clean those contacts to the starter as well.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
If all else fails swap out the DME relay under the driver seat.
Which could be battery, connection, or any connection on the fat yellow wire from the ignition switch, through the bulkhead connectors to the 14-pin plug in the engine bay or any of the ground return straps.
'77 S with '78 930 power and a few other things. |
Well, it was an easy fix. Just needed new battery. I guess I thought it was more when a year ago the car would not start on a local trip to the mountains. A whack on the starter fixed it. But the new battery (Interstate 85 month) is starting her up strong. I think I will save for a new starter anyway! Thanks, Nick
muck-raker
where is this 14-pin plug located in the engine bay, exactly?
