Need help to ID this SC sensor please
Picture one shows a sensor that is unplugged straight back, other sensor on the right is plugged in. I believe one of these is the idiot light for the oil pressure gauge.
Second pic is far right on the engine close to the bumper, again unplugged - what does this do?
I appreciate the help, the PO has changed so much I am still trying to figure things out.
Old 09-27-2012, 08:44 AM
Scott R's Avatar
Which year SC is this? The sensor on the right chain cover is the 50c temperature switch for the lambda unit.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 09-27-2012, 08:46 AM
Sorry -1983 SC that has been converted to carbs. As the lambda unit is unplugged I can assume that sensor is not needed?
Old 09-27-2012, 09:13 AM
Scott R's Avatar
Yea, you don't need any of that stuff for carbs. I should have guessed carbs since you can actually see the oil breather in your picture.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 09-27-2012, 09:32 AM
Temperature switches......
The first one on top of the engine near the breather hose is the 35°C/95°F SW and the other at the chain housing cover (right side) is 15°C/59°F SW. Both needed for CIS fuel injection system and disabled for carburator system.
Tony
Old 09-27-2012, 10:15 AM
Great. What sensor is the one plugged in towards the back with a red top on the first picture?
Old 09-27-2012, 11:37 AM
howard freeman's Avatar
Oil pressure Idiot light.
Howard
Howard Freeman
80 911 SC & 74 914 1.8
79 930 & 83 SC coupe,03 996 TT,02 996 C4
03 X/5 3.0. 370,186 miles now Sons daily driver
10 X5 3.0I 224,515 miles
Old 09-27-2012, 12:15 PM
