msd ignition
I'm thinking about changing out my bosch ign. for the msd talked about in 101 projects. Although my 82 runs fine, the fuel mileage could be better. Since I can't drive slow I figured this multispark system might help. My question is, how do i adjust the spark plug gap for optimum performance to comply with 101 projects.
Hi:
Having installed a LOT of MSD's in my time, I honestly cannot tell you that the fuel economy grew appreciably better, but the starting and drivability certainly did,... ![]() ![]() Of course, plug gaps must be opened up to take advantage of what the MSD's are capable of. Buy a sprak plug gapping tool at your auto parts store and its very easy to do. Be aware that some plugs come pre-gapped and should NOT be changed so I use either Bosch or NGK copper plugs and sometimes Bosch Silvers.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Hi Steve, what do you recommend the gap to be?
James 1969 911E Slate Grey 1981 911SC Wine Red 1997 911C4S Ocean Blue |
Naturally aspirated motors running MSD or Crane CDI's can run between 0.040-0.045+" plug gaps. This is less for forced induction motors running non-standard boost.
You may even be able to run a larger plug gap than 0.045", so adjust gap and drive to ensure you're not misfiring under heavy load. Find the sweet spot and leave it there ![]()
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition ![]() |
I've read a bit about this topic and haven't commited yet. A lot of guys say it only helps at lower rpms (under 3K). In my case I spend at least 40 miles during my commute at 60mph
![]() Couple questions: Given the above commute should the car should run "smoother"? And improve on Mpg?
Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
I put a MSD in my 83SC myself and I love the results. I run a .06 plug gap. I initially installed mine b/c of a problem called "bucking" that my car was having that was a very very scary deal and if you have had it you will know what I mean. The bucking in my case was being cased by a rev limiter that was starting to fail. Since I put the MSD system in is starts much better in cold and especially in wet where I was starting to have trouble with the Bosch. Plus I would swear it revs to red line faster than before. It idles much much better. Best part is for a tight wad like me is that I installed it myself, almost paid for the entire MSD system with the money I made from selling my Bosch 6 pin bax (the bucking was not being caused by teh Bosch box but by the rev limiter up in my dash). By having my neighbor make me an aluminum bracket I was able to mount the new MSD box in the same spot as the old unit also even thought the old one is smaller if you make the bracket right you can fit it there and even still use the same mounting holes. Good luck and it is a mod that is worth it IMO.
83SC black on black 01 Chevy S10 08 Buick Enclave |
I had an MSD 6AL in my BMW race car for about 1 1/2 years, that's maybe 11 races, and it failed. Needless to say, I wasn't impressed.
Enemy of the State Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it. |
Well I think we can all agree that a purpose build race enviornemnt is far different that a daily driver enviornment/part time track or DE kind of enviorment Dave. Plus, I know people who race and they swear by MSD so your experience may be more of a one-off nature than the norm. I would bet that the issue was with 3 letters but that the 3 letters where BMW rather than MSD.
Could be that you did get a bad one. It happens a lot in electrical components. Did you contact MSD to see if they were willing to do anything for you? You know I am playing with you about the BMW remarks. I think they are a great red-headed step-child for Porsche. I hope the PanAmerica takes a lot of business away from the step-child too. Why Porsche didn't make a sedan before they made a SUV I WILL NEVER KNOW...
I dont think you are going to see much of an improvement in a 911SC unless you have modified the engine. I swear by the MSD6AL on Amercan muscle cars. You can feel a big difference at the higher RPM's, it gets better gas mileage and it has its own rev limiter. I put one on my SC about a year ago to see if there was any advantage and couldnt feel any. I did not dyno or check the gas mileage.
If your stock Bosch is not working it is a fine replacement, but I wouldnt do it as a performance enhancement.
Smoke 1982 911SC Rosewood SCWDP # 0097 |
I'm not a huge BMW fan either. I love racing the '02 because there are several in my class where I race and ITB usually has a big field, and it doesn't cost much to run a season, relatively. The '02 has been pretty reliable considering.
I don't own one but from with the data compiled on this list the Bosch CDI seems to be a good design, reliable and easy to repair. I am not sure what the advantage to an MSD unit would be.
I think early S man has the complete service manual in a thread. |
DaveE -- BTW, what sort of gap were you running on the plugs prior to the MSD failing?
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
One advatage to the MSD system is that it is a helluva lot cheaper than the OEM Bosch unit. A new Bosch unit is like $1400 from the manufactuer. I found rehabbed ones and used ones ranged from $300-$450. I think I spent $175 on my MSD set up with the Tach sending unit. So you have 21st Century technology that costs 8 times less than 20th Century technology I would call that a HUGE advantage unless you have money you are just looking to try to clog your septic system up with.
MSD reverse engineer 6 pin CDI |
So do you see enough difference in the Bosch unit that would compel you to send 8 times the amount of money on it?
"I don't see too much 21st century technology in either, they look similar"
Rick is correct. The MSD has no proven advantage with the multiple sparks below 3000 RPMs with the major disadvantage of less reliability the result of more components. Read here under Ignition Systems for more info: www.systemsc.com/technical.htm
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone Last edited by Lorenfb; 04-06-2007 at 08:24 AM.. |
"8 times the amount of money on it?"
Do what???? No one does this! Pelican sells rebuilts as do others.
Senior Member
The 'real' price of used, working Bosch units is typicaly $100. That makes Bosch LESS expensive, rather than more.
I heard from a very experienced Porsche guy that some 911's respond well to the MSD system, and some do not. Some 911's run more poorly with MSD than Bosch. And.....overall it has been my observation that MSD and Permatune both have a WAY WAY higher failure rate than Bosch. Yeah, we've heard of Bosch units failing. But it's rare. Everybody has a Permatune or MSD failure story. I think Warren and Glenn both chuckle at guys who think they are "upgrading" to MSD.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
