Taking it apart is easy
Diagnosing a bent Fuchs problem - answer found
My steering wheel vibrates and has a side-to-side wobble. These things are more noticeable at speeds of ~70+ mph.
The wheels were re-balanced to 0.00 on the balance machine. No real improvement. The wheel bearings appear to be nice and snug, with no play evident. One front wheel has some curb rash. This came with the car, and no other wheel shows any such damage. Therefore, I set up this sophisticated measuring device ![]() ![]() Rotating the wheel indicates a gap between the chalk and the wheel at the point where the curb damage exists, but the chalk squeals against wheel the rest of the way around. Here's the gap. It is about 2mm. I don't have a dial gauge to measure exactly. ![]() So, my question is, is a 2mm sideways bend in the wheel enough to cause a very noticeable wobble in the steering wheel? This wheel is the only one where I found such a flaw. Where else should I look?
Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com Last edited by Jerome74911S; 10-02-2012 at 09:08 AM.. |
How old are your tires ? If they are not too old, I would try to get a road force balance on a Hunter road force balancer before I did anything else. It is possible that your wheel is part of the problem. Start with the simple things first.
Thanks for the idea. I'd have to hunt for a Hunter. The tires are 3 years old and seem to be round.
Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com |
During a recent CB and alignment, my tech reminded me of the very slight bend in one of the reare FUCHS that will need repair. he states that the repair process will involve heat...
Inanycase,...he stated (in my situation) it wouldn't matter, as to balance (he jokingly stated that he can balance a square, if necc'y). Best! Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
There is a shop near here that seems to do a nice job of repairing aluminum wheels. What should I ask about with this?
Regis turd ab user
Sounds like you might have a warped brake rotor? I did with similar sypmtoms.
David Last edited by 911s55; 09-30-2012 at 12:23 PM.. |
Would I feel a warped brake rotor in the brake pedal? The brakes feel smooth when operated.
out of balance is the most likely scenario. even if they were done before, there's no guarantee they were done right.
I took the wheel and tire to a shop that does first-rate wheel repair and straightening.
Yes, I was right, the wheel is bent - about 1.5mm. This is not enough to bother about. The tire, however, could be seen wobbling back and forth, side-to-side, about 5mm. This is enough to cause vibration and shake in the steering wheel. The tire, after all, is a bigger diameter and heavier 'flywheel' than the lighter, smaller wheel, so its affect on what is felt in the steering wheel is greater. I'm going tire shopping. Unless there is a way to straighten a tire.
Under the radar
Every time I have bought new tires in the past 5 years I have had vibration issues. (four sets, three different cars, three different stores) I fixed it every time with my home made bubble balancer. I am not sure why those spin balancers all the tire shops use can be so bad. That being said in your case I would suspect the tire is out of round.
How much weight do you have on the wheel to achieve a "perfect" balance? I have to use almost an ounce, which tells us that I need to have my wheel straightened. Are you using that much weight?
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
No, a lot more than an ounce. Like 4+.
Yep. You and I will both be sending out our wheels for repair this winter. We have a great place in Bath, Pennsylvania. I am sure you have a decent place as well up in the Quebec area.
Best of luck. Nice car, by the way.
Thread Tools | |
Rate This Thread | |
