Homemade splitter redux
Ok, so I was tired of sanding.
I went to the local surplus yard today and bought a sheet of 1/8" aluminum. Slapped down my template, and in about 15 minutes had my new splitter. I made this one a little less aggressive, bringing it rearward about 2", or even with the oil cooler opening. I still managed to screw up though - backing out of the garage, the untrimmed trailing edge caught an air line laying on the floor and ripped the bumper off. Grrr. I spent 2 1/2 hours putting *that* back together... Investment in the aluminum splitter - a little under $13, plus some liquids for my friend Manuel Labor, who does all my metal work - he works cheap.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
How did you affix it this time? And the big question - did it pass the Fitz highway test?
Chuck Moreland - elephantracing.com - vonnen.com |
Thom
That looks familiar. One suggestion though. On mine I made two seperate pieces, one for each side and then made two of each. that way if your ever at the track and have an off or hit a curb it doesnt rip the whole thing off. I ripped the drivers side one off once and luckily it was just a matter of putting a another one on at the track.
Michael |
Montana 911
ok, I am going to ask the question
What does the splitter do? Aerodynamics?
H.D. Smith 2009 997.2 S 3.8 PDK 2019 Ford Ranger Lariat FX4 Baby Raptor 2019 Can Am Renegade 1000R XC 2020 Yamaha YFZ450R |
At speed, there is a high pressure zone that forms in front of the bumper and valance. This high pressure pushes down on the top of the splitter to create downforce.
Montana 911
ahhh, I see the light. Does this also help the flow of air through the openings instead of having the airflow directed below the splitter?
Mine is also in 2 pieces, primarily for portability. I plan to breed this pair now that they're in captivity.
Chuck - they're held on the same way, with big fender washers and grade-8 bolts. Yes, I know, the fiberglass is the weak link; I just used what I had laying around. They passed the late-night Fitz-test, which consists of the Auburn Blvd ramp on 80 - a nice long, stretch, usually empty, with some gentle curves to it. Quote:
