Carpet question...
As part of my post rodent infestation clean up I am attempting to clean the carpets and trunk felt. They are all original and in good shape, but could use a cleaning. Is it prudent to use a steam cleaning machine to do the job? I believe the carpet to be Haargarn if that helps. Thanks.
Ass-engine Nazi slot car -- PJ O'Rourke
Old 10-03-2012, 05:58 PM
muck-raker
kidrock's Avatar
I have a personal steam cleaner that I use all the time, with no problems. I would be careful with choosing the right detergent or cleaning solution, which could cause some irreversible problems.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 10-03-2012, 08:13 PM
I used to clean carpets with one of those Bissel cleaners that heated the water. They have an upholstery attachment, but you can rent a simllar machine if you don't have access to a similar one you an borrow. I found I could clean a carpet (indoor) as well as a commercial company, maybe better if you take your time. The thing I found out was you had to rinse the carpet two or three times. Not soak it, but rinse it as the machine instuctions call for. I quit using commercial cleaners in favor of a product named Folex, which is a wetting agent used for spot cleanup. It did as good or better job with no leftover fragrance & less residue. To do a proper job you need to remove the carpet, but that's your decision. In your case considering you had the rodent problem, I would seriously consider one of those solutions (for use in the machine) that removes pet odors maybe after you clean the carpet & it has completely dried. Have fun.
Marv Evans
'69 911E
Old 10-03-2012, 08:34 PM
