jobenz's Avatar
trunk lid will not open on my 930
help anyone, i cannot get my trunk lid to open. it worked fine last week, today nothing. any ideas??????????????? the cable appears to be intact.
Thanks, Joe
Old 06-11-2002, 06:02 PM
pjv911's Avatar
Send a message via AIM to pjv911
If the cable releases all tension it will also open it just like pulling it. Remove the knob and let the cable go in further. If it dont just pop open push down on the hood . I would try pushing down while someone pulls the cable before you take the pull knob apart. Remember NO screwdrivers for prying.
Kurt Williams
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 06-11-2002, 06:37 PM
targa911man's Avatar
Bentley's has a procedure for "emergency" trunk opening, but it involves drilling so is a last resort. If Kurt's methods don't work, lmk and I will post or email it to you.
Dan Morissette
'85 Guards Red Targa 911
My Owners Gallery Page
Non illegitimi carborundum
Old 06-12-2002, 07:18 AM
mperkins's Avatar
Send a message via AIM to mperkins
pjv911 has it right.
this happens to me from time to time.
i push down on the lid a bit (lower center)
and then go back and pull cable and it should pop open.
having someone push down on the lid at the same time you pull on the cable helps also.
Old 06-12-2002, 08:07 AM
Senior Member
Hello
The trunk lock needs sometimes lube and readjusting.
Lube is done at every regular service.
Grüsse
Old 06-13-2002, 02:19 PM
