Expansion Valve
1988 911 3.2 I am installing a new expansion valve, does the thermal coil attach to anything?
Old 10-04-2012, 06:55 PM
T77911S's Avatar
yes. it should be attached to the LOW side line exiting the evap. wrap it with that black "tar" stuff to insulate it. its best if you can attach it at about the 4 or 5 oclock position or the 7 or 8. not on top.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 10-05-2012, 04:35 AM
Does the whole expansion valve coil need to be covered or only the pigtail part that's touching the low side line?
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 10-05-2012, 06:51 AM
a/c fixin
Great. Thanks. Any ideas where to get that black tar stuff?
Old 10-05-2012, 06:57 AM
T77911S's Avatar
just the bulb. there is usually a clip that holds the bulb against the line.
basically, the bulb measures the temp of the refridgerant leaving the evap and opens or closes the expansion valve per the demand of the heat load
RACE CAR:: sold
Old 10-05-2012, 07:41 AM
Fleabit peanut monkey
Bob Kontak's Avatar
It is called prestite tape.
Santech/30 ft. A/C line prestite tape (MT0450) | | AutoZone.com
1981 911SC Targa
Old 10-05-2012, 08:33 AM
I've wondered if we could use some of that spray in expanding foam in this situation since getting the tape around the bulb can bt a PITA and hard to reach in tight spaces with a bunch of other stuff near and in the way.
Buck
'88 Coupe, '87 Cab,
Old 10-05-2012, 08:43 AM
T77911S's Avatar
it would suck when you have to replace it again.
RACE CAR:: sold
Old 10-05-2012, 08:59 AM
Bob Kontak's Avatar
Maybe not with the latex foam. Not the petroleum/solvent based stuff.
1981 911SC Targa
Old 10-05-2012, 09:07 AM
kuehl's Avatar
The correct position for the capillary sensing pigtail (aka 'bulb') is 12 o'clock, directly on top of the evaporator outlet tube.
You can use whatever insulating material you wish to wrap around the pigtail, however Prestite is the most common. And, don't forget to seal off the opening in the top of the evap box where the evap outlet pipe and TEV inlet pipe exit.
You don't need to wrap the entire TEV in insulation, only the cap sensing pigtail.
Old 10-06-2012, 05:24 AM
T77911S's Avatar
u are correct. i brainfarted
RACE CAR:: sold
Old 10-09-2012, 06:20 AM
