Gas tank + Battery + frontal impact = WOOOSH!???
With my gas tank out for a repair, I started thinking about how it would look if it took a hard smack in the front, the tank seam looks like it may burst fairly easily and with 12 volts sitting in a plastic box about 6" away, seems like a recipe for crispy critters.
Do the front tank porsches go up in flames any easier than other cars in a frontal crash? Might get some nomex undies for xmas! Although this one below did okay
They are pretty robust and I don't think there is a special propensity for immolation.
Porsche engineering including crash testing will allow the best result under given circumstances. A frontal impact in a front engined car can rupture fuel lines under pressure , and the battery is nearby also. The spare tyre is designed to spread some of the impact. Round surfaces on tanks impart considerable strength. You can put the battery in the smuggler's box if it makes you feel safer. I don't lose sleep over the position of the tank/battery.
'81 924 , '85 944 , '78 911SC , '82 928 5.0L "They run best being run close to the ‘limit’ and done so regularly" - Grady |
If you hit something hard enough to rupture the fuel tank you wont live to see it.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
muck-raker
there's a lot of info on this, carried on many previous threads. Many of these same vehicles have taken some considerable damage, and I can't remember an instance of combustion from the front. It's actually pretty amazing, the amount of front end damage these cars can handle.
Now, fires from the rear? Much more to be concerned about.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
Do not remove the spare tire...it is part of the design. Early crumple zone technology.
1990 964 C4 Coupe & 1991 964 C2 Coupe (current) 1989 911 Targa (sold) 1996 993 Cab. (sold) 1999 x2 Boxster (sold) 2006 Cayman S (my daily) |
Interesting picture - Cop, guy in a Santa suit and check the length of the heels below the passenger door. Toss in the damage, and therefore the speed.. looks like an interesting story behind the crash.
Kinsley 1980 SC Targa - MS2, EDIS |
Hopefully I won't have to back up my words but I believe it would be easier to bail out of an open targa top, if you're doing this type of smoke show. Of course the coupe guys will claim that the open top will only allow more air into the cabin therefore allowing a more speedy combustion of the occupant. It is an interesting debate question.
btw, where was that photo taken? |
I had the same thoughts on the details in the crash. NYC, incredible spike heels, Santa Suite driver.......must have been some office Christmas party!!!
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
Banned
Safe to remove the spare tire? Last edited by Ronnie's.930; 10-11-2012 at 07:26 AM.. |
It's actually 5th Ave and 19th St., NYC. Part of Taxi Driver was shot there.
View Larger Map Saphora was the clue...
72 911T 2.4 MFI 2017 Escape SE 2.0 turbo 2020 Honda Civic Touring Sport 1.6 turbo 10' Madone 5.2/17' Lynskey ProCross |
Saw a 993 cabro at dC auto that hit a tree dead on. Speedo stuck at 110. Deep concave damage between the fenders. Think the car was a little cross eyed. Fuel tank did not rupture. Everything from the doors back was in good shape. Pretty amazing cars.
gary 70T coupe forever almost done 88 Carrera Targa diamond blue |
Pure B.S.
1986 3.2 to 3.4 conversion |
From what I can tell, there is no definitive answer one way or the other. You can call it BS if you want, but mine will stay in.
Thanks for the replies, seems like there is no issue.
When I was googling images I couldn't find a single case of a fire starting at the front but plenty of the Engine or something burning in the back so that was interesting. Does seem like the targas may be faster to get out of, but I like to think that if the flames were licking at my polyester encased goolies I'd make it out of the coupe sunroof just about as quick! The story of Father Xmas and the power pole is here. Or if the link doesn't work google jalopnik + Porsche + santa and see if that works Google Image Result for http://cache.jalopnik.com/assets/images/12/2011/12/xlarge_87bba1f03d26fa7a4f3954f4a9dada5c.jpg |
In response to Justin's speculation about crumple zones, there was an advertising piece from back in the the day (maybe '69 or thereabouts) featuring a 911 that had impacted a tree at speed. Don't remember the text exactly, but it did discuss the benefits of the spare tire up front helping to protect the occupants in such a crash. Never underestimate the Porsche engineers and how far ahead of the times they typically were.
It (fire) happens
Man Killed in Cardiff Crash Identified - Encinitas, CA Patch The spare tire "crumple zone" theory is a big controversy over on the Corvette forum also, again with no proof either way. Last edited by eastbay; 10-11-2012 at 06:22 PM.. |
Banned
All you really need to do is look at how the 911 spare is attached and common sense tells you that it wouldn't do jack **** in the way of crash protection.
