It took only 49 years!
mclmk8d's Avatar
Question Cleaning and Maintaining RSR Frosted wheels?
I just got my wheels back from Harvey and they are stunning. What I need to know is how do I keep them looking that way? I've used Sonax gel Wheel cleanere on my painted WRX BBS wheels with good results, but feel that might be too strong for the anodized finish.
Any experiences good and bad would be helpful. I have another thread here with photos of the new wheels RSR Frosted Wheels on Red Coupe It was started as a quest for photos before I had the wheels done.
Serge: In the heart of Philly!
Daisy - 1972 911T 2.7L Light Yellow
Veronica - 1987 911 Carrera Coupe Indischrot, M&K GT3 muffler and Euro Pre-Muffler, SW Chip SOLD
Lil Blue - 2002 Subaru WRX Wagon (my dd/HPDE car) SOLD
Old 10-11-2012, 01:33 PM
Mr9146's Avatar
Harvey says let 'em sit in the sun to get good and warm and then use some Palmolive dish soap and water.
According to Harvey, Letting them get warm opens up the pores in the wheel and the oils and dirt rise to the top allowing the soap and water to do their job.
He also said that sometimes it can take numerous washes to get the dirt/fingerprints/oils out.
Good luck.
Old 10-11-2012, 03:19 PM
Cooper911SC's Avatar
I use either Griot's or P21S.
I agitate with a 2" wide natural bristle paint brush (Purdy) and create a good amount of foam. This helps float out the brake dust.
The Palmolive doesn't sound like a bad idea either.
I agree that several passes are sometimes needed, esp. if the wheels have been handled while dirty. Finger prints can be tough to remove.
My $.02, Cooper
Old 10-11-2012, 05:07 PM
Formerly known as Syzygy
Canada Kev's Avatar
Harvey also suggested the dish soap method with mine. P21S gel also works great. Using a brush with both will help. For every day cleaning I usually use just regular car wash soap and a brush.
Kevin
Old 10-11-2012, 05:29 PM
mspirito's Avatar
Be careful off dog pee! I had a set done by Harvey and got some dog interest and was not seen and not cleaned for a few days and it made some permanent marks!!!
Old 10-11-2012, 05:44 PM
An old trick is to apply a thin coat of Vasoline (or equivalent) onto the wheels (cleaned). Buff with a soft, clean cloth. This interposes a thin protective layer between the wheel and any brake dust and cat pee that's applied. As needed, use a mild car wash soap to remove the Vasoline and whatever there is on top of it. Dry, then reapply Vasoline.
Sherwood
Old 10-11-2012, 08:59 PM
skinnerd's Avatar
On Harvey's freshly refinished wheels with the RSR frosted finish, I don't believe you want vaseline, P21S, or any other fancy Dan cleaner any where near the wheels.
Harvey just said mild soap and water, and dry well when finished.
Don't allow dirt or brake dust to sit on these wheels for very long.
I think they do require some additional effort to keep them looking nice....but it is worth it in the end.
All the guys at our recent Beer and Burgers thought the newly re-finished wheels on my car looked outstanding.
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 10-12-2012, 01:59 AM
I've used Gibbs penetrant on my Weidman RSR finish wheels since day 1. Basically after cleaning and drying the wheels wipe on Gibbs and let it soak for a few hours (or overnight), then wipe off the excess. The Gibbs seems to pull any oils and contaminants out of the surface of the wheels. It also makes future cleanings easier for a month or two. When the wheels start getting dirty again simply reapply.
Gibbs makes maintaining RSR finish wheels easy!
Gibbs Brand penetrant
Gibbs Brand Lubricant at GIBBSBRANDLUBRICANT.COM
Old 10-12-2012, 02:59 AM
