Brake line tab on RSR struts
Hi,
I'm installing a pair of RSR struts which don't have a tab for the hard brake line to soft brake line connection welded to the strut tube like the Konis I'm replacing. I did some searching to see what others have done, but wasn't able find any photos. . . So I thought I'd post pics of what I fabbed up this afternoon - Just wanted to make sure I was on the right track. I was planning to either zip tie or hose clamp these brackets I made to the strut tube. I'd love to see what others have done to compare etc.... Thanks, Tom ![]()
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
Navin Johnson
I made a tab similar to yours, and welded it directly to the strut in a location that made plumbing all the lines together convenient...
Don't have any pictures handy
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
What's Facebook?
I use this method on my race car. No problems in over 7 yeas.
Bilstein 74' RSR Coil-Over Struts Photo Gallery by slidevalve911rsr at pbase.com
Turborat "’Cause every once in while, the lion has to show the jackals who he is” 1979 911 SC - 2100 LB track rat 1986.5 928 5-Speed - 36,000 miles 2001 330Ci |
I welded-on a bracket:
Roland 930 Turbo '81 Too many modifications to list |
Thanks for all the responses. . . looks like I'm on the right track. I'm not sure if I'll weld on the tabs or just hose clamp them on; looks like either way will work.
Thanks again, Tom
