Banned
73 911E 2.4 to 3.2 conversion wiring~~help
Hi
I am doing 73 911E 2.4 to 3.2 conversion wiring, but I have problem with 1973 911E rear 14pins connector diagram, can any one help me!
Many thanks!
Old 10-10-2012, 05:39 AM
E Sully's Avatar
This is from my 1973 911T to '86 3.2 conversion.
Ed
1973.5 T
Old 10-10-2012, 06:38 AM
Banned
Thanks E Sully. It really help.
But I still have some parts can not ID. Can any one tell me these two connector is for ??
Old 10-10-2012, 07:25 AM
Banned
Can any ID these two connector for me, they came from engine.
Old 10-10-2012, 07:27 AM
Those are the connection for the oxygen sensor in the cat converter. The single is the connector and the 2 wire set is the heating wires for the ox sensor. they connect into the brain harness.
Also, there is a 3 wire plug that is sometimes used to run the sensor with a connector that is offset in the connector so it only fits one way. Get the other ox sensor so you match the brain harness.
The split appears to be between 85 and 86.
Bruce
Old 10-10-2012, 12:33 PM
Banned
Can any one help me ID more cable?
Hi Bruce
Thanks a lot, really appreciate at that, I still have some cable can not ID, can you help me with that?
Bruce
Old 10-11-2012, 08:23 AM
E Sully's Avatar
Green wires ar for a/c. Black is for up shift light on 3.2 gage, black/violet is the tachometer, yellow goes to yellow from ignition switch. Other 2 black wires, one is for ignition coil, other is for anti-theft. Both need to be connected to wiring that is hot in run and start from ignition switch. Red/green is fuel pump, wire in a 25 amp fuse.
Ed
1973.5 T
Old 10-11-2012, 09:27 AM
Banned
HI E Sully
Thanks a lot, another question, I saw your previous diagram, there are some red dots, green dots and yellow dots, what is that mean?
Old 10-12-2012, 04:43 PM
E Sully's Avatar
Indicates whether I needed them or not. Read this thread.
HELP Please! with another 1973 3.2L implant
Ed
1973.5 T
Old 10-13-2012, 06:10 AM
Banned
Hi Sully
Thanks!!!
Old 10-17-2012, 06:18 AM
Banned
Another question, how to run DME cable into car body? Any suggestion place to drill hole?
TIEN
Old 10-21-2012, 04:35 PM
E Sully's Avatar
Drivers side under rear seat. I am returning mine to original engine and have welded up the hole I used for the DME harness.
Ed
1973.5 T
Old 10-22-2012, 04:39 AM
Banned
Thank E Sully!!
Any possible to run it like late 84 car?
Old 10-22-2012, 07:39 AM
E Sully's Avatar
That is how they ran it. Here is a link to another conversion showing cable routing.
Modification
Ed
1973.5 T
Old 10-22-2012, 08:09 AM
Banned
any possible i split-up the DME connect than go with original hole?
Old 10-22-2012, 08:51 AM
