David's Avatar
Question I give up on CIS, need shop advice in Houston
I've been trying for months to get a '78 SC to run that's been parked for 5 years. I've cleaned out the fuel system and the fuel distributor piston. I've replaced the fuel filter and dead fuel pump. Now it starts but when I try to rev it, it backfires and dies. The fuel pressure is about 40psi. I've looked for a vacuum leak but I can't find one.
I would appreciate any more advice on what the problem could be, but what I really need is some advice on a good Porsche shop in the Clear Lake area of Houston, TX.
Thanks,
Old 06-12-2002, 05:43 PM
Have you inspected the airbox?
Michael
'98 Boxster in Ocean Jade Metallic
Old 06-12-2002, 06:38 PM
wckrause's Avatar
Isn't that quite low for CIS?
Bill Krause
We don't wonder where we're going or remember where we've been.
Old 06-12-2002, 07:07 PM
makaio's Avatar
Very, for a CIS 911.
Old 06-12-2002, 07:51 PM
David's Avatar
What should the pressure be?
Old 06-13-2002, 03:54 AM
Somewhere in the Midwest
MotoSook's Avatar
system pressure should be 65-75 PSIG (with the WUR isolated, motor off, ignition-fuel pump on).
you should see a "warm" pressure (with the WUR in line) that corresponds to the curve for your motor. see Bentley manual or factory manual.
Old 06-13-2002, 07:29 AM
I got backfiring because my mixture was not set right. I was way too lean so I bought one of those 3mm T-handled allen wrenches
and rather then playing around with a CO meter just experimented til I had it perfect. I did alot of replacing (airbox, cold start valve, WUR, intake runners, etc.) before I finally found this was the simplest solution. "Left lean - Right Rich".
Good luck
Bob
73.5 T (home of the first CIS)
Old 06-13-2002, 11:01 AM
