can you use a 3.0l in a 3.2 car?
i have bought an '87 911 with 135000 miles on it. good car but the top end will have to be built. I built an engine off of a 3.0l case and heads and the engine only ha 5k miles on it. I went all out and did everything to this engine to go into a 914-6. I have decided to put the original engine back in it so I am going to be left with this engine.
The case is '78 SC standard sized cylinders with JE pistons 9/1, heads are '78-'79 SC heads, with webcam 120/104. I know everybody usually talks about taking their 3.2 out and putting a 3.6 in but I already have this one and I am hoping to be able to use the 3.0l block I already have with the 3.2 injection.
Will I be able to bolt all of the stuff on the 3.2 right on the 3.0l case and it work correctly?
Ideas?
Jimmy
Old 10-25-2012, 02:53 PM
ROW '78 911 Targa
timmy2's Avatar
Seeing as people bolt 3.2 intakes onto their 3.0's for bitz injection yes, but the intake runner size may be different on the large port motor. I'm sure it can work with adaptors if needed.
Old 10-25-2012, 03:08 PM
KTL KTL is online now
Schleprock
KTL's Avatar
3.2 injection can be made to fit. You need some longer studs on the intake side of the heads if I recall correctly because the 3.2 manifold wants some plastic isolators (tech term is phenolic spacers) to avoid heat soak into the manifold.
Problem is your 3.0 cams are not agreeable with the 3.2 injection system. The 120/104 has less cam lobe separation (more overlap) and more duration than stock cams or even modified cams designed to improve 3.2 performance. Those changes don't play well with the single throttle body and air flow meter.
So I think if you get a different set of cams you'll be better off. But the ECU programming is also a challenge. The 3.2L chip mapping and fuel delivery is set up to feed a 3.2 displacement. Your lower displacement 3.0 will need some help in terms of chip mapping to get the mix right.
Kevin L
'86 Carrera "Larry"
Old 10-25-2012, 03:13 PM
Laneco's Avatar
I assume that at some point, you would like to freshen the 3.2 and put it back into the car. To that end, the idea should be to do as little to the car as possible -right?
Maybe putting a set of PMO carbs on the 3.0 is an idea. Use the existing fuel pump, etc, buy the regulator/bypass that Clewett sells, and have at it. Easy and clean.
When you are ready to put the 3.2 back in, you still have a nice 3.0 with PMO's on it. The PMO's sell well even used if you decide to get rid of them. Your total penalty of time and money would be very reasonable to go this route (provided you sell the PMO's when you're done).
angela
Hello
Old 10-25-2012, 04:00 PM
The cams I can change..no sweat. I am more concernedabout the mapping
I sure don't want to go to some problem maker engine
Old 10-25-2012, 04:03 PM
I have had carbs for years and love fuel injection so I want to stick with theDME
Old 10-25-2012, 04:07 PM
How are you going to mount the flywheel sensors?
Bruce
Old 10-25-2012, 06:32 PM
Well.. don't know yet. I was hoping someone here had done this and could tell me.
I just have a good motor in stock that I would like to keep whole. If I can't do this I will just build the top end of the 3.2 and be done with it. I have done 914 conversions and am not in any way wanting to do radical changes to the car or motor.Hate to not use a 5K motor but may not be able to unless someone has experience doing this.
Jimmy
Old 10-25-2012, 08:03 PM
sell both the 3.0 and 3.2 to fund a 3.6 conversion?
Old 10-25-2012, 08:40 PM
TibetanT's Avatar
Subscribing...this will be fun!
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 10-25-2012, 10:48 PM
TibetanT's Avatar
Guess my question is...can this be done? Aren't the flywheels different? The 3.0L flywheel doesn't have the TDC pin for the reference/speed sensor, correct? I know the flywheel mating also is slightly different as far as the crankshaft is concerned, but probably can be worked around.
Also, would you need to swap out the DME/ECU for the earlier K-Jetronic box, or is that not needed since the 78/79 3.0L didn't have the O2 sensor. Hmmm?
Ed Paquette
1983 911SC
1987 944S
Old 10-25-2012, 10:58 PM
Band.
If you're thinking 'temporary' then IMO Angela has definitely given you a very elegant suggestion, that involves very little changing of engine internals and/or electronics; and a financial outlay that you can recover much easier than the alternatives.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 10-25-2012, 11:23 PM
Schleprock
KTL's Avatar
Honestly just do the top end on the 3.2 If you don't mind changing the cams on the 3.0, then you gotta know that doing a top end is simple.
135K on the '87 is nothing. Have a friend who has 170K on his '87, drives it like a madman on the track, and it just keeps on purring like a kitten. Not much indication that the engine has ever been opened up, doesn't use oil excessively. Impressive.
Kevin L
'86 Carrera "Larry"
Old 10-26-2012, 07:23 AM
If it were me, I would drop the 3.2, refurb the heads, which is usually not a budget buster, replace the exhaust dilivars with steel, chain rails, etc. Put it back in the car and sell the 3.0. The 3.2 will be good for another 100K and you will have a pocket full of cash. I have PMOs on my 70 and love them, but motronic is sure easy to live with.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 10-26-2012, 07:24 AM
Thanks for all the advise.just trying to save some money and use what I already have finished but I will shelve the 3.0 and do the original heads on the 3.2
That being said..Let me redirect the question.
who can do the 3.2 heads without any changes to them. Restoring them to original condition and about how much is that going to cost me?
Again thanks for all this advise!
Old 10-26-2012, 09:53 AM
Schleprock
KTL's Avatar
cgarr will set you up. He's done a number of our heads in our local group of guys.
Kevin L
'86 Carrera "Larry"
Old 10-26-2012, 10:08 AM
Thanks Kevin I sent him a message
Old 10-26-2012, 12:20 PM
Are you really going to put that 3.0 back on the shelf???
I have a 74 914 that needs a 3.0. Let me know.
Old 10-26-2012, 04:53 PM
I can sure fix you up NORD.I have all the conversion stuff
engine tyranny coolers oil tank suspension flares valances.....everything.
PM me
Old 10-26-2012, 06:27 PM
I've sent you a PM. Don't need flares, I like slab side, also not a track car,
well maybe alittle
Old 10-26-2012, 06:46 PM
