Wire from Ceiling
Hi, I have a hole and a grey wire hanging down from the front window. Any ideas what 'should' be there... I do have a rear view mirror mounted to the glass down below the picture(not sure if that setup is stock?), so it doesn't seem like it would be for a rear view mirror... It's also not the clip for the sun visor, that's over to either the left or the right... any ideas?
![]() Any ideas on the above Pict? Thanks! J
J 911 SC - 1980 911 S - 1977 |
That is the electrics for the nipple that hangs down for inside temperature and controls the box between the seats that pulls the lever for heat.
Bruce |
Oh... that would explain why when I turn the heat on even to just position 1, the lever lifts all the way up... I actually still have that nipple, found it on the floor but didn't know what it was for... I guess I just need to buy the base for it...
Thanks!
any idea of the name of the part? having a tough time finding it in the Pelican parts catalog... Thanks
Sure doesn't look stock....
Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
sudo apt-get purge 930
Actually it is stock. My car had one too but mine is missing. Those things are worth their weight in gold because everyone is missing theirs.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
Fleabit peanut monkey
Agree. Way too modern of an adapter.
1981 911SC Targa |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Sensor.
It is indeed the Auto Heat sensor with was later moved to the dash due to breakage(s) when adjusting the sun visors. Here are a few pics: ![]() ^early 911 ![]() ^ 3.2 Model year The sensor part (911.659.105.01), and harness (911.612.50.00) have been NLA for many years, but here's the CKT. ![]() Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 10-06-2012 at 05:35 PM.. |
Base P/N
Here is the base P/N:
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Well, that just shuts me right up. :-)
1981 911SC Targa |
That blurry pic made it look like an 1/8' phono plug!!!!
Doyle
Thanks for the help on this! Awesome to know now. Doyle, Sorry about the blurry picture....
El Duderino
It's hard to tell from the pic, but there is a thermistor (I think that's the right term) that sits inside the rubber nipple. Make sure it's there and plugs in securely. You also might want to use a DVM to check the resistance on it to make sure it's within spec before you button it up. If you search on auto-heat troubleshooting you'll find a thread with the specs.
No worries, J. Glad you got the information you needed,..great group of people here!
BEST! Doyle
Thermistor spec.
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 10-07-2012 at 11:01 AM.. |
So now I'm trying to locate an interior temp sensor rosette for th 1980 911. As mentioned above, it is a small, rectangular, plastic piece with a central hole flanked by 2 screw holes. It is mounted up between the sun visors & helps to hold the sensor for "climate control" device in place. Part number is 911 571 235 01. I've been told it is NLA so here I am..... If any of you might have one please let me know.
Really appreciated! thanks
ROW '78 911 Targa
You might want to post a WTB (want to buy) in the used parts classifieds. Someone parting out a car may have one.
Rosette
Having the sensor in hand, you could make something up. Try member andrew15, he's up in Canada. good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 10-28-2012 at 12:33 PM.. |
