Rescuer of old cars
Arne2's Avatar
Question ['84 Carrera] Intermittent wipers run too fast
First, those of you who don't drive in the rain can probably just move on, nothing to see for you here.
But for those of us whose cars do get wet, is the intermittent function of your wipers slow enough to be worth using?
On my car ('84 Carrera), when the intermittent knob is turned just off the click, the wipers sweep every 3-3.5 seconds. Turn the knob farther and the frequency increases. By a quarter turn, they are running constantly and further turning of the knob (obviously) does nothing. I have a brand new potentiometer (knob switch) and pulse generator (relay) in the tub o'spares that came with the car, but neither one changes anything.
I'm more used to a normal intermittent delay being around 6-7 seconds, 3 is just too short to be handy in the steady mist that often plagues our winter months here in Western Oregon.
So I'm curious - is the 3 second sweep normal for these cars? If so, has anyone come up with a way to slow them down a bit? Maybe add a resistor between the pot and the relay?
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 10-27-2012, 07:41 PM
plumb4u2's Avatar
I have only used mine a couple times and I believe 3-4 sec is what mine does at slowest position
Justin
84 Carrera Targa
98 F-150 4x4
Old 10-27-2012, 07:59 PM
Amochosto's Avatar
Mine (84 Carrera) sweeps more frequently when you just switch it on and when you twist the knob further it slows down. I actually have never had a problem getting the wipers to sweep at the correct speed for my preference and I tend to like the wipers to go slower than most other drivers I see.
1984 ROW 911 Carrera Pacific Blue Metallic Practically no options other than sunroof and custom paint.
2009 BMW E90 M3 Interlagos Blue
Old 10-27-2012, 08:42 PM
Rescuer of old cars
Arne2's Avatar
Yours slows down the farther you turn it?? Mine doesn't, it goes faster. I wonder if the wires on my knob switch are reversed?
2018 718 Cayman 2.0
Old 10-27-2012, 08:45 PM
It took only 49 years!
mclmk8d's Avatar
Arne, mine also slows down the more you turn it. As you conjecture, your wires are most likely reversed. I have an 87.
Serge: In the heart of Philly!
Daisy - 1972 911T 2.7L Light Yellow
Veronica - 1987 911 Carrera Coupe Indischrot, M&K GT3 muffler and Euro Pre-Muffler, SW Chip SOLD
Lil Blue - 2002 Subaru WRX Wagon (my dd/HPDE car) SOLD
Old 10-27-2012, 08:49 PM
Rescuer of old cars
Arne2's Avatar
Just took my Bentley out to the garage, removed the clock and then pulled the knob switch out to compare the connections to the wiring diagram. Sure enough, the wires for terminals 15a and 15b were swapped. After I corrected that, the intermittent wipers work as they should - about 3.5 seconds between wipes just off the click, with increased delay the farther I turn the knob.
Thanks to all who replied. Pelican is great!
2018 718 Cayman 2.0
Old 10-27-2012, 09:14 PM
Amochosto's Avatar
Awesome!
Old 10-27-2012, 09:42 PM
Amochosto's Avatar
Just to follow up, I had the opportunity to drive in the rain today, I counted out 18 seconds between sweeps on the slowest delay setting.
Old 10-28-2012, 11:40 AM
