Boy did you luck out!
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 10-30-2012, 09:49 AM
wacko's Avatar
Originally Posted by James Brown View Post
i think your fine, you can get plenty of heat without the fan. a little backdating will get even more heat. take the insurance cash and get some goodie, keep trucking!!
What exactly does"backdating" mean?
1978 RUF 911SCR
Old 10-30-2012, 12:49 PM
OsoMoore's Avatar
Originally the heating was just 2 ducts from the engine fan straight into the heat exchangers and to the front of the car. Later they changed to a single duct from the engine fan into a heater blower, and from there through two ducts to the heat exchangers.
The original design is much "cleaner", and doesn't leave hoses snaking all over the engine bay. On the other hand, if the engine is at idle you get very little airflow and may disturb cops by revving at stop lights.
Backdating is taking out your heater blower and going to the older low-hose method. It makes the engine look better, and is easier to work on. Its not too expensive, and you can even pull off some very cheap backdates with some ingenuity and the right sort of saw. If you search this subforum you'll find lots of info on it.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery.
Old 10-30-2012, 01:10 PM
BoxsterGT's Avatar
Porsche Crest
First thing is to determine the cause of the fire.
From the looks of the smoke pattern & the intact Plastic bits on the left side, it seems it began on the right side. There's not much in the way of a cause on that side except oil.
I have a C2 here that caught fire when it had just been removed from long term storage. The owner had it idling outside a Dunkin Donuts, and came out to find it ablaze. It began on the rt side where oil had dripped onto the heat exchanger and there just happened to be a mouse nest in the same location.
The owner got the fire out, or I should say the fire dept got it out, but only after a bit more damage as in busted out rear window and crispy paint over the rear deck & melted bits in the engine compt.
I daresay your incident is very minor. A good cleanup & some new plastic bits appears to only be needed.
You are extremely lucky it was not worse and you and your precious daughters were not hurt. Now your first incident is over, you can look forward to happier times. This cleanup is a good way to begin that close relationship with your Porsche that most of us Pelicans enjoy with ours.
The best to you & family, and welcome.
Len
Old 10-30-2012, 03:08 PM
you see Arthur...
jasonlee's Avatar
I have backdated heat on my 82 SC, an no problems up here in BC. For engine work you could try Jaokob's or Scan automotive both on the north shore. As far as paint goes, Corva would be my suggestion. I had an acquaintance whose 80 SC caught fire and di about 9K worth of damage, surprisingly ICBC paid to fix it.
J
82 911 SC, Cat bypass, Flowmaster 1 in 2 out lightweight flywheel and backdated heat
06 Cayenne S
00 ML 55 AMG
Santa Cruz Bullit
Old 10-30-2012, 03:13 PM
you see Arthur...
jasonlee's Avatar
here are before and after pictures backdated heat
before
after
J
06 Cayenne S
00 ML 55 AMG
Santa Cruz Bullit
Old 10-30-2012, 03:16 PM
MBAtarga's Avatar
Would a leak up at the the oil switch or engine thermostat cause that?
Mark
'83 SC Targa - since 5/5/2001
Old 10-30-2012, 05:20 PM
Under the radar
Trackrash's Avatar
Hard to believe an oil leak would have caused that. I have oil leaking on my heat exchangers all the time. (don't ask). Of course I'm not driving an SC, so anything is possible I guess.
I had a vapor recovery line rubbing on my heat exchanger which finally wore through and ignited.
Probably a good idea to replace every rubber hose on the car.
Gordon
'71 911 Coupe 3,0L outlawed
Old 10-30-2012, 06:24 PM
Fire was on the wrong side for a 911, something other than fuel lines.
Bruce
Old 10-30-2012, 06:35 PM
Retired Member
Brian 162's Avatar
It looks like it started around the compressor. It could be those the wires by the filter. I have backdated heat as well on my sc and it gives me lots of heat when I take the car out in the cold weather.
80 911 SC sold
17 Tahoe
07 Z06 Corvette
Old 10-30-2012, 06:59 PM
Senior Advisor
James Brown's Avatar
based on the smoke pattern maybe the compressor might have seized, remove the belt, repair the wiring and fire it up paying close attention around that area til the engine is warm.
08 Cayenne Turbo
Old 10-30-2012, 07:11 PM
Originally Posted by john walker's workshop View Post
just fix it yourself and keep ICBC out of it. looks minor.
Just wanted to re-quote this as it is very sound advice and the way to go.
Old 10-30-2012, 07:17 PM
Originally Posted by gamin View Post
I carry 2 fire extinguishers.
Sorry for the second post but this is also VERY good advice. Buy them cheap at COSTCO and put them in the car. Just remember to secure them and don't forget to put them back in after you clean the interior. This has saved many a car.
Old 10-30-2012, 07:19 PM
1979 911sc
Windsor4273's Avatar
From the looks of the burn patterns, it appears as though the fire started on the passenger side. Fuel line leak?
1979 911sc
1969 Rover 2000 TC
2000 Ford Excursion
2015 Ford Transit 350
Old 10-30-2012, 08:20 PM
Functionista
manbridge 74's Avatar
Being that fire was on a cold day in Canada, I'm thinking oil on heat exchangers wasn't it.
I'd guess a very fine fuel leak mist and stray ignition spark. Be advised that it is hard to see this fine mist and every precaution shoul be taken before engine is started. After it's running check plug wires for leaking voltage at night with lights off and a spray bottle of diluted salt water. The salt helps conductivity and will expose ignition shorts.
Old 10-31-2012, 07:21 AM
Dublinoh's Avatar
Had you recently filled the oil? oil change? looks like it started low on passenger side. Could enough spilled oil cause this type of fire? Glad it turned out as well as it did.
Old 10-31-2012, 11:37 AM
Two Rivers's Avatar
Looks to me it was an oil fire. I had one in the shop with that area cooked. The oil cooler was leaking onto the exaust.
Valkyrie
Old 10-31-2012, 01:02 PM
Scott R's Avatar
Same fire location as my car, only I have/had plastic fuel lines and that caused a lot more damage. For me it was the wire harness to the starter that did it, rubbed in just the right place I guess started burning up the rear wall.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-31-2012, 01:09 PM
