CDI Box problem
I am having a problem with my Bosch CDI box. When I have the ignition on I cannot hear the whine from the CDI and the car will not start. I have to wiggle the 3 pin connector around the most of the time I hear the whine start and everything is ok. I unpluged the 3 pin connector and cleaned them and di-greased them. I took apart the CDI box and did not notice anything broken in there where it connects to the circuit board. Still does not fix the problem. Anyone have any other ideas?
Thanks,
Jason
1972 911T MFI
1995 911 C2
Old 11-02-2012, 12:33 PM
emac's Avatar
Jason albeit I have a six pin and have been told they work or they don't period, I had the same issue with mine. It lasted about a week and then bit the dust. I would start looking for one
Ernie 81sc
Old 11-02-2012, 12:59 PM
Well, you could check all your grounds. I had a loose one between neg on my battery and the chassis and it fried the cdi.
And just os you know, there are plenty available at all the usual rebuilders and ebay - esp if you have a rebuildable core.
1972 911T/S MFI Survivor
Old 11-02-2012, 01:08 PM
Check the PCB
Jason,
Remove the printed circuit board and re-solder the connections where the 3 pins go thru the PCB. Sometimes the solder will crack where the pin goes thru the board and the crack is not visible to the human eye.
Bob B
Old 11-02-2012, 01:12 PM
RETIRED
Joe Bob's Avatar
Talk to Ingo, 3.6@cox.net
2012 ML350 3.0 Turbo Diesel
Old 11-02-2012, 01:35 PM
T77911S's Avatar
Originally Posted by NICE 69 S View Post
Jason,
Bob B
+1. Could be a bad solder joint. Could also be a bad connection INSIDE the 3 pin
Connector. (Broken wire)
You will have to do some more very careful wiggling. Do it with the engine running.
I would check the wiring first. The CD unit repair requires more work and skills
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 11-02-2012, 04:49 PM
