poorshe911's Avatar
911 door stay replacement help request
What are the tools required to remove / install the 911 door stay?
The body side seems to have a wierd pin or bolt.
Thanks foir any help.
Old 06-14-2002, 08:04 AM
Senior Member
Superman's Avatar
I recommend using the door repair plates available at Pelican. They are used along with the style of door stay that does not have the built-in studs, but rather uses bolts that go through two holes in the door stay.
I would also recommend grinding off at least part of the two humps on the door stay rod. Those humps apply a great deal of back-and-forth pressure agains the door bulkhead, which causes the door sheet metal to rip, over time.
Now, to your questions: The pin you mentioned must be driven out, with a suitable drift and hammer. The door stay itself is fastened by two Allen bolts, at least in the case of the stay that takes through-bolts. You can see the fasteners through the little hole that the stay penetrates.
You will need to remove the interior door panel, since the stay is removed and installed from behind. Perhaps just removing the speaker will provide access. Anybody know?
Mocha 1978 911SC. "Coco"
Old 06-14-2002, 08:12 AM
Sean Hamilton's Avatar
Thumbs up Check out Wayne's 101 book - he knows.
There's a very good article on this whole proceedure in plain English including photos. Note also the tip for reinforcing plates.
Cheers, Sean.
94 911 Carrera 2 993 Cab
http://www.pelicanparts.com/gallery/Sean_Hamilton
Old 06-14-2002, 08:40 AM
rfix'n's Avatar
Where is said article?
Rob Fix
'78 3.6L SC Targa
Eiche Gruen Metallisch
Old 06-14-2002, 08:50 AM
Thumbs up
It's in our host's book:
101 Projects for your Porsche 911
Wayne R. Dempsey
Project 74 - Door Stay Replacement and Reinforcement. Page 180
Cheers, Sean.
Old 06-14-2002, 10:55 AM
poorshe911's Avatar
Ah ! That book ! I have the book. I'll check it out.
Thanks.
Mike '83SC
Old 06-16-2002, 09:16 AM
