emac's Avatar
Fog Light issue
Here's the story, my left (drivers side) fog light went out. I bought new bulbs from our sponsor and replaced the bad one. Started the car turned on the lights and fog light switch and no light. Took out the bible and seen that it could be fuse #1 checked and its good. At this point I am stumped. Can anyone help.
Thanks in advance
Ernie
Ernie 81 SC
Old 08-25-2012, 11:25 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Thanks in advance
Ernie
Ernie,
Assuming you have cleaned the connector, did you verify ground from the brown wire at the bulb socket to ground point MPI?
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 08-25-2012, 12:11 PM
emac's Avatar
Not yet but what stumps me is the right light works. It looks like they both grnd at the same point. With that I would think both would be out. I will check
Thanks Ernie
Old 08-25-2012, 12:24 PM
Thanks Ernie
Also, clean and check for voltage at the two pin connector.
1986 911 Targa.
Only in L.A.:
Old 08-25-2012, 02:19 PM
emac's Avatar
I know there is no such thing but where 2 pin connector?
Old 08-25-2012, 02:25 PM
Connector.
1. Clean this connector.
2. Check for voltage/ground accross thease pins.
1986 911 Targa.
Only in L.A.:
Old 08-25-2012, 03:47 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Connectivity issues are the biggest problem with fog lights. Listen to 86 911 Targa and do what he says.
I have an 81.
Old 08-25-2012, 03:52 PM
muck-raker
kidrock's Avatar
I've had this issue before, and I found one of the wires was burnt due to the extreme heat those fixtures emit. Gerry's suggestion is an excellent one, hopefully this will be the issue with yours.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 08-25-2012, 07:46 PM
Fuse Panel Connection.
Verify the connections (2) at the bottom this fuse.
1986 911 Targa.
Only in L.A.:
Old 08-26-2012, 07:00 AM
emac's Avatar
86 911 Targa
Thanks to you and all, I found the issue, a broken wire behind the main fuse terminal. But now my issue is the car wont start. She normaly fires up on the first crank but for about the last week it takes a little more. I have no spark and have a very bad feeling that its the CDI box.
I give up quite pissed and going to lay down.
Ernie 81 SC
Old 08-26-2012, 10:11 AM
No Start.
86 911 Targa
Re-post under "car won't start".
1986 911 Targa.
Only in L.A.:
Old 08-26-2012, 10:22 AM
kohho's Avatar
Hello "86 911 Targa" - where did you get that electrical wiring diagram? I've just purchased an 84 euro-spec Targa and there's a problem with the fog light wiring. I won't get into the details (yet) but would definitely like to get my hands on the proper wiring diagrams.
Thanks!
Carl
Old 11-06-2012, 10:01 AM
Thanks!
Carl
This is your source, send him an inquiry.
1985 Porsche 911 Carrera Service Manual Supplement | eBay
Note: there may be some minor differences from the U.S. to the Euro.
Also:
Manuals - Porsche
1986 911 Targa.
Only in L.A.:
Old 11-06-2012, 10:30 AM
