Will Turbo Twist Wheels fit on my ´07 GT3?
I recently bought a 2007 997 GT3 and I am looking forward to take it to the track.
I am looking into options for track wheels, but before going the $$$$ way, I would like to consider a less expensive (free in my case) option. I have a set of spare 18" Turbo Twist wheels. Would those fit on the GT3 without the need of spacers?
I calculated the backspacing and outside clearance and it seems not to be a problem. But I am not sure if the brake calipers will clear properly.
Unfortunately, I have not received my moving yet (recently moved to Spain), so I can not test the Turbo Twist on the GT3, myself. And my moving will arrive only a couple of days before my first track event.
So has anyone tried thses wheels on a 997GT3? Anyone sees a potential problem in using them?
For reference, the specs on the stock and Turbo Twist wheels:
OEM GT3 wheels:
-Front: 8.5 x 19 ET53mm
-Rear: 12 x 19 ET68mm
Turbo Twist wheels:
-Front: 8 x 18 ET50mm
-Rear: 11 x 18 ET54mm
Mario
'76 911 w/'97 3.6 Euro Vario Engine & Turbo body kit & TPC Supercharger
'15 GT3
Old 11-12-2012, 03:16 AM
Anyone?
Old 11-12-2012, 12:21 PM
Bill Verburg's Avatar
OEM GT3 wheels:
Turbo Twist wheels:
here's where the outer edge of the lip sits compared to OEM GT3 wheels:
8ET50 is 3.35mm more inboard, ie a 3.35mm spacer would put it in the same place as oe
11ET54 sits 1.3mm more outboard
Bill Verburg
Old 11-12-2012, 02:58 PM
Thanks Bill.
Would I be able to use (safely on track) a 4mm spacer (I don´t think 3.5mm exist) with the stock wheel bolts?
Thansk again
Mario
'15 GT3
Old 11-13-2012, 12:14 AM
Thanks Bill.
Thansk again
Probably or you could live w/ an inset wheel
the rule of thumb for our 14mm bolt or stud is to have 14mm of engagement
I forget the thread pitch on our cars but for 1.25 that's 9 full turns, for 1.5 it's 7.5 turns
Bill Verburg
Old 11-13-2012, 05:37 AM
Bill
living with a 3.5mm inset wheel won't be a problem for me, but what I need to know is if the wheel will clear the brake calipers, which are larger than the ones on a original car which came with the Turbo Twists. As I mentioned, the problem is that I don't have the 18" Turbo Twist here in order to test fit.
Any idea if there might be a problem there? Do you know of anybody usding these wheels on a 997 GT3?
Thanks again
Mario
'15 GT3
Old 11-13-2012, 11:37 AM
