Question Which 911 motors/distributors run off vacuum advance?
About to start the process of tuning up my 914 with a 6 swap and upon initial inspection noticed that my distributor has a provision for a vacuum line, but does not have one fitted. Also looking around I don't see a disconnected hose nearby and/or a provision on the manifold for a line to originate.
The motor in my car I believe was originally built up from a 2.4 liter case, but could have an array of mismatched parts. Can't say with 100% certainty which dizzy is in my car though as access to the distributor is close to nil with the landscape of a 6 cylinder 914. With this being the case another issue that I know I'm going to be running into is how to see a timing light down in there.....if anybody has some tricks on this please chime in as well.
I figured a search around the board would answer my question, but the info I found has me confused, as it appears that all 911 distributors have a provision for a vacuum line.....Though it also seems that some don't use vacuum advance as well.
Old 11-12-2012, 02:52 PM
The 2.4/2.7 vacuum unit is a retard. The timing is set with the vacuum line connected. For example, I was doing a 76 S and the spec calls for 5 degrees ATDC with the vacuum connected 950 RPM. Disconnect the vacuum and the dist jumps to 10 to 15 degrees BTDC.
The true 914/6 timing is done off the flywheel. The 2 liter flywheel has markings and can be seen down through the notch of the bell housing from the top.
Bruce
Old 11-12-2012, 06:34 PM
Since originally posting this thread I have gleaned that the motor in my car was built off a 911/51 case. According to Bruce Anderson's book this was the 72/73 mechanical injection E motor.
Still trying to ascertain if I should have some vacuum line hooked up to my distributor. One is not connected at the present time, nor do I see a lines coming from the intake manifolds of the now equipped Weber carbs. I'm hoping that perhaps the original mechanical injection and distributor combination utilized a vacuum run distributor, and it was abandoned when the motor was rebuilt and the Webers were swapped on?
Old 11-21-2012, 07:23 AM
RETIRED
Joe Bob's Avatar
Hook up a timing light.....rev the motor and see if you have advance.
2012 ML350 3.0 Turbo Diesel
Old 11-21-2012, 07:43 AM
There were no provisions for vacuum lines in either MFI or Webers.
Old 11-26-2012, 02:51 PM
Fleabit peanut monkey
Bob Kontak's Avatar
I also saw a post recently where Early S man said NO vacuum advance on distributors before the SC.
1981 911SC Targa
Old 11-26-2012, 02:55 PM
BURN-BROS's Avatar
You can see the brass vac port on the throttle body. They are located on #1 and #4 cylinders on 1972/73 MFI cars. .
Earlier MFI systems had no vac provisions.
The Carburerated cars had vac retard around 1971 and it may have been California only.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 11-26-2012, 04:00 PM
moneymanager's Avatar
But, again, it retards, not advances, timing, at least before 74.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 11-26-2012, 05:36 PM
BURN-BROS's Avatar
The only distributors that have vac advance are 1980+ SC's and 930's ,everything else is retard.
Burnham Performance
Old 11-26-2012, 06:49 PM
