white rabbit
Send a message via Yahoo to Don LaVance
Backside valve adjustment tool question
I am ready to do the backside valve adjustment procedure and have everything I need except the "No Go" feeler gauge.
I have seen it identified so many different way's as to cause me to not be sure what size to order. I have the Starrett .0025 gauge for the go measurement.
What is the correct one to order for the no go.
1. .0030
2. .030
3. .003
4. 0.003
5. 0.3mm
I have seen it written in all the above ways on the various forums regarding this priocedure . Which should I use? Are some of the ones listed (1 through 5) the same?
Or can I simply use a .07mm as a go gauge
and
.08 for the no go gauge.
Thanks for your help and advice.
Don
Old 11-13-2012, 09:28 AM
76 911S Targa
Two and a half thousandths for the go gauge, 3 thousandths for the no go gauge. They are very thin. Buy a feeler gauge set and take it apart. Wrap different colored tape around the ends of the 2.5 and the 3 thousandths pieces to identify them and use them separately. One guy here has used them taped end to end to keep the package together. That seems like a good idea to me. Once you are set up this method goes very quickly.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 11-13-2012, 09:46 AM
Banned
The Pelican article on the "backside method" answers your questions regarding which feeler gauges to use:
Pelican Technical Article: 911 Valve Adjustment - The Backside Method
BTW: .0025 = .063mm and .003 = .076mm
I have always been able to find feeler gauge sets with these sizes at Autozone, Pepboys, NAPA, etc.
Old 11-13-2012, 09:55 AM
Banned
#s 1, 3, 4 in your list are the same measurement and #s 2 & 5 have nothing to do with this process . . .
Old 11-13-2012, 10:00 AM
kodioneill's Avatar
Recently there was a post where a Pelican used two Popsicle sticks taped together with the gauge in between to give some support for the gauges. I think this is a great help to get the proper feel.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 11-13-2012, 10:13 AM
white rabbit
Thank you for the response,
I feel more comfortable with which to buy and use for this.
Don
Old 11-13-2012, 04:09 PM
On the popsicle stick idea - put "go" on one end "no go" on the other, marked in some way so you don't have to read the gauge to know which is which. I used green and red shrink wrap to make it real easy.
Took a while, but got to a good result using backside. Will be much quicker next time
Kinsley
1980 SC Targa - MS2, EDIS
Old 11-13-2012, 05:36 PM
diy83sc's Avatar
I used a green tie wrap for the the go and ... red for the no-go.
Old 11-13-2012, 05:55 PM
