Super Moderator
Chris ---------------------------------------------- 1996 993 RS Replica 2023 KTM 890 Adventure R 1971 Norton 750 Commando Alcon Brake Kits Last edited by cstreit; 06-17-2002 at 07:58 AM.. |
Hey Chris--
When I think about this kind of stuff, I think "Classification." Let's see here. . . PCA CLASS I --------------- '70-71 911T 2249# 125HP 17.99 lb/hp (2.2) '72-73 911T 2310# 130HP 17.77 lb/hp (2.4) Advantage: 2.4, which has more torque anyway. Dick Strahota turned a 1.04.8 at Lime Rock in our club race. I think he's running a '73 911T? But. . . it depends on the cams and the induction. . . PCA Class G --------------- '72-73 911E 2365# 165HP 14.33 lb/hp (2.4) '70-71 911S 2249# 180HP 12.49 lb/hp (2.2) Advantage: 2.2, if you keep the revs up. Having said the above, I am rapidly learning that the folks that you would consider to be at a disadvantage due to weight generally have bigger tires: I got STOMPED in the club race by a 1975 911S, which checks in at 2425#, 167 HP, 14.52 lb/hp, which is almost equal to my '71 911E at 2249#, 155 HP, 14.51 lb/hp, except that the later car RUNS BIGGER TIRES! Also, everybody is a better driver (for now!) but in my view the extra weight doesn't make that much of a difference. By the way, if you wanted to build a car for PCA Class G, I would recommend an SC-- the tires and suspension make them the class favorites. Hope this helps in your decisionmaking-- I only know about PCA, when you get into HSR and other venues, the rules are different (guys run GT-style cars with 2.5's!)
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
