Spark plug threads
Is applying anti-seize on spark plug threads a good idea?
Fleabit peanut monkey
Sure. Just a smidgeon on the threads.
1981 911SC Targa |
Member 911 Anonymous
Copper based is best
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
French Import
Just read somewhere on this forum yesterday that Porsche advised against it as it reduces conductivity thus decreasing the spark.
Personally I never use anti-seize on spark plugs, but it is a matter of personal preference.
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
Flat Six
I use just a little Permatex Hi-temp copper-based anti-seize. Easy-peasy. Have noticed no ill effects on ignition. But I can see how that might be an issue if you use too much. Then again, copper's a pretty good electrical conductor . . . .
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
French Import
Found the Porsche Tech Bulletin...
1981 911SC Targa |
Well then "NEVERMIND" SNL :-P Tre Bien Monsuir!
Going to do my plugs tomorrow :-P
French Import
Dude, do you ever leave that poor car alone?
Thanks, I was thinking a very little would not hurt.
However, I will follow the bulletin. Thanks again. |
muck-raker
damn, I just did my plugs....guess I'll wait until the next 15K checkup. Dry, indeed.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations ![]() |
I use anti-seize on the threads but a miniscule amount. I've been doing it for many, many years on all the cars, including the 911s.
I GUARANTEE that if you use too much, the plug won't spark. Been there, done that. ![]() angela
Hello http://forums.pelicanparts.com/off-topic-discussions/1102514-we-lost-amazing-woman-yesterday.html |
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
French Import
I had just read a thread on that issue the day before and a quick search returned this pic posted by a member of this forum. Gotta love it when info is still fresh in your mind!
Interesting comment in this month's Panorama Tech section. Guy having trouble getting a plug out and the moderator sez........use a bit of anti seize next time.
15 year PCA member ![]() 1972 911 E Coupe - gone now 1987 Mazda RX-7 2+2 - still cooking Swift DB-1 FF & Swift DB-3 F2000 -not forgotten 1979 911SC 3.0 & 2000 Camaro |
French Import
If you ask 10 people you will get 10 different opinions.
![]() In the end it is what makes you comfortable that matters. ![]()
This is a tech bulletin from NGK regarding anti-sieze. Spoiler alert - they say not to use it.
1986 Porsche 911 Coupe |
Well ngk is what I use, so I will make it so :P
Chain fence eating turbo
You do not use anti-seize due to the plating on the spark plug threads.
81% stable 67% of time
The Porsche owners manual also says change the oil every 12,000 (or 15,000) miles and CASIS says shift at 2100rpm. I change (and shift) at 3,000. Lotsa choices. ![]()
Best regards, Mister Moo '87 Carrera Targa '07 BMW R1200R |
