dazed and confused
john baldwin's Avatar
gas tank empty over the winter?
Every spring it takes ~ 3 tanks of 93 octane to purge the winter storage gas/Stabil mix before she runs strong. This 10% ethanol fuel must be a water sponge...
Has anybody tried leaving the tank nearly empty, adding Stabil to that (in the highest concentration) and running it to see it through the system?
I'm wondering if this way it shortens the "cleanout" time in the Spring or does an empty tank just make for even more water condensate in what fuel there is?
89 Carrera 3.2 Targa
2011 BMW 335d
2013 BMW X3 3.5
80 911 SC Weissach Coupe (Sold)
Old 11-20-2012, 05:19 PM
Been here a while
Empty tank equals rusty tank. Never had a problem with ethanol based fuel after winter storage. I always makes sure my tank is completely full for winter slumber.
looking for 1972 911t motor XR584, S/N 6121622
Old 11-20-2012, 05:32 PM
87 - 911
It would make for more condensation collecting in the tank over the winter, possibly leading to rust in the tank and contaminated fuel in the spring. Filler up with the freshest fuel in town and add stabil, if concerned with the amount of ethanol in the fuel you might look into using the marine grade stabil (green). Can't get a worse environment than a boat for having moisture issues with fuel.
Old 11-20-2012, 05:34 PM
dshepp806's Avatar
Load her with non-ethanol...
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 11-20-2012, 07:06 PM
dazed and confused
non-ethanol
where do you find it?
2011 BMW 335d
2013 BMW X3 3.5
Old 11-20-2012, 07:12 PM
Reiver
Reiver's Avatar
full tank with stabil.
Old 11-20-2012, 07:13 PM
ROW '78 911 Targa
timmy2's Avatar
Find a location near you. I have 2 stations within 5 miles. Expensive though....
Ethanol-free gas stations in the U.S. and Canada
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 11-20-2012, 07:15 PM
SweetWaterSurprise's Avatar
Always left my collection with full tanks and stabil.
Old 11-20-2012, 07:23 PM
MConn's Avatar
My car doesn't sit over the winter, but my boat owners manual said - if pure gas, fill the tank to avoid condensation; if ethanol gas, leave tank as empty as possible because ethanol will stratify at bottom of tank.
Old 11-20-2012, 11:53 PM
Bill Verburg's Avatar
an empty tank will get H2O condensation in the tank
E10 can absorb H20 from the air, which then separates out w/ temp change leaving a slurry of H20 at the bottom of the tank
That's why you add Stabil or Star-tron to the full tank
I can't even leave a gallon of lawn mower gas in the garage w/o adding stabilizer to it
Bill Verburg
Old 11-21-2012, 05:38 AM
Concur with full tank and stabil. I never had the issue with running rough for a few tanks but then again I always ran the first few tanks with fuel injector cleaner to remove any crud build up that may occur from fuel in the small passages of the injection system.
Tony G
2000 Boxster S
Old 11-21-2012, 08:20 AM
dazed and confused
Stabil it is
Thanks guys...appreciate all your inputs
A full tank it is then and on to those rear wheel bearings!
2011 BMW 335d
2013 BMW X3 3.5
Old 11-26-2012, 06:48 PM
Formerly known as Syzygy
Canada Kev's Avatar
And in the spring, run the tank until it is almost empty before you fill. That'll get rid of any remnants of the previous year's fuel much quicker.
Kevin
Old 11-26-2012, 09:04 PM
Pump out the old gas at end of winter and run in the garden equipment or a lesser car.
A full tank prevents water condensation from air moving in and out of the tank, less air space in tank means less air can flow in and out, the air can bring in moisture and leave it consdensed on the cold exposed inner walls of the tank. This is not so much a concern if stored in a dry heated space, It can be a big concern in a moist space with wide and often temperature swings (unheated garage)
Old 11-27-2012, 08:25 AM
I have done this several times with no problems. This is the best idea to go with. It costs nothing but time and everything is covered.
Just don't siphon it out with your mouth before putting into the lawnmower....
Old 11-27-2012, 10:18 AM
