86FlatSix
JQ911's Avatar
Krylon - Stained Glass Paint - DIY project
Does anybody have an experience with Krylon paint? I plan to paint my fog light lenses with amber and I came up with Krylon Stained Glass paint from most car club forums. It says it requires several coatings to achieve desired amber color as the one available is yellow. TIA
74 BMW 2002 (rust rocket)
86 911 Coupe (weekend warrior)
09 997.2 C2 (semi-daily)
Old 11-20-2012, 05:01 AM
Almost Banned Once
sc_rufctr's Avatar
Old thread about yellow lenses.
yellow H4 lenses ?
- Peter
Old 11-20-2012, 05:09 AM
86FlatSix
JQ911's Avatar
Thanks for the lead!
Old 11-20-2012, 05:17 AM
Justin@Athens's Avatar
Send a message via AIM to Justin@Athens
Faded Tail Lights - Page 3 - Rennlist Discussion Forums
1990 964 C4 Coupe & 1991 964 C2 Coupe (current)
1989 911 Targa (sold)
1996 993 Cab. (sold)
1999 x2 Boxster (sold)
2006 Cayman S (my daily)
Old 11-20-2012, 05:24 AM
I installed yellow LED's in my fog lights.... not as bright as the regular H-4's bulbs, but I like it.
It's as bright as my parking lights.
Old 11-20-2012, 07:35 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Given the time of year, temperature will impact the flow of paint. Warm up the paint can under water and paint in at least +60 degrees. Put the lenses on a board and carry them inside between coats if your garage is not heated well.
I have never used the paint, though. If it is recommended in more than one place it ought to be fine.
1981 911SC Targa
Old 11-20-2012, 07:53 AM
Ive used that stuff a ton of times.
Multiple light misting coats like with any other spray painting project.
Ryan- Sad day when my 83 911 left me
Old 11-20-2012, 09:45 AM
vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
I used stained glass paint on my '67 tail lights. It worked great. This was about 20 years ago and went looking for the paint again and could not find it. The car has since been totaled so can't speak to how well it holds up.
Let us know where you found it for future reference.
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 11-20-2012, 11:12 AM
86FlatSix
JQ911's Avatar
DIY paint the fog lights yellow
So the Krylon Stained Glass Paint (YELLOW) arrived last night and I thought I'd try to paint the fog light lens since it was high 50s this afternoon. It took me 2.5 hours to dry it up with 4 coatings every 30 minutes. I don't think I got the right yellow shade of the euro fog lights but I can redo it further as it was starting to get dark so I decided to call it a day.
Old 12-04-2012, 02:48 PM
Looks good to me!
Old 12-04-2012, 02:50 PM
mmari270's Avatar
Was planning on doing the same, does it look? How about with the lights on?
Old 12-04-2012, 03:52 PM
Hydrocket's Avatar
Looks fine to me!
1986 911 Targa We affirm that the world’s magnificence has been enriched by a new beauty: the beauty of speed. A racing car whose hood is adorned with great pipes, like serpents of explosive breath - a roaring car that seems to ride on grapeshot....
Old 12-04-2012, 03:59 PM
86FlatSix
JQ911's Avatar
I haven't tested the lights yet but with 4 coatings not sure if it would be as bright as the clear lenses. Even if I was using clear lenses, its not bright as those HIDs anyway. Will revert back to you later I'll test the lights and check if it totally dried up.
Old 12-04-2012, 04:40 PM
Undocumented User
McLaren-TAG's Avatar
Don't know if you noticed but you did a pretty bad job with overspray and covered up most of your front license plate.
Old 12-04-2012, 04:46 PM
86FlatSix
JQ911's Avatar
The can says, test spray on other surface before actual application.
Old 12-04-2012, 04:58 PM
Old 12-04-2012, 05:35 PM
86FlatSix
JQ911's Avatar
So I let it dry up overnight and just tested the fog lights a few hours ago. It sure has the same brightness as my clear lenses.
Old 12-05-2012, 02:19 PM
Where did you buy the paint from? I have been looking everywhere and have called alot of arts and crafts store. No one seems to have any in stock.
Old 12-08-2012, 02:58 PM
86FlatSix
JQ911's Avatar
Bought it online, just search for Krylon Stained Glass Paint. Cost including shipping is around $15.00
Old 12-08-2012, 03:06 PM
noavgdrvr's Avatar
spray paint
Michael's, the Craft Store sells it... It was on sale at the Michael's near me for .99 cents a can.
I haven't sprayed my fogs as yet. I ended up buying some very expensive yellow bulbs. I wasn't sure I'd like the look of the fogs using with the yellow paint.
I'd love to see what they look like shining behind the painted lens.
After seeing this, I may do it.
Old 12-08-2012, 04:39 PM
