Tail Light OUT, All of them 1985 Porsche Euro 911
My Porsche has all the brake lights out. Both left and right and the whale tail. I checked the bulbs, nothing. I dont have a meter to see if it is getting power, but obviously its not. Could it be a fuse somewhere just for the tail lights or is there something else that could control it?
I appreciate ANY help. |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Brake light switches.
Or, Fuse #7. What is your M/Y? Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 11-22-2012 at 02:01 PM.. |
Thanks Gerry, I have a 1985 EURO 911 Convt. Trying to solve the mystery before buying new parts... All my manuals and fuse boxes are in german! haha. Can I switch the fuse with another to test? And if so, what fuse?
Member 911 Anonymous
Sure you can.
If you can buy a Digital Volt Meter, even if it is a HF one, better to have one than not having one at all. So the car is the "on" position and when you depress the pedal it does not light? Jim
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Jim, no, even if the car is on the lights do not work. If I start the car and pull out the lights switch to turn all the lights on, the two rear lights turn on just to the outside of the "Porsche" Red Lens. The next slot over I assume are the brakes? That section of bulbs on the left and right do not work at all. The next section of lights are for the turn signals, and when I click to turn left and right they both work as they should.
This tells me the brakes light issue is not the bulbs or the housings. Something MUST be in the fuses OR another control for just the brakes. |
pm
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Fuse first!
Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
You got Dr Gerry on it, you will be set.
As Doyle stated, check the fuse and the lines going into the fuse holders to make sure they are connected. Next would be the Brake Light Switches (BLS) Jim
