Bthibo
MFI throttle body
Gentlemen I greatly appreciate all info included in this forum. I have been refurbishing a 1972 911 E. I was putting the throttle body back on and discovered that one of the tabs to screw body down is broken. This is the body that has the butterfly's. The body is made of a plastic material. My question is can this be fixed and by who? Thanks for your input
bob t 1972 911 T |
911 rookie
I've got a set for sale. Interested?
Bthibo
All I need is one side. How much?
bob t 1972 911 T |
Can you post a picture? Not clear if you are describing the throttle body or intake stack.
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
Sounds like the velocity stacks. You could try the local PU bumper welding/repair guys. Just don't use the 'Porsche' word...they may do it for free. I had one repaired like that some years ago.
Bthibo
No, it is not the velocity stacks, but the body throttle body the holds the butterfly valves. I. Will try and post pics tomorrow.
bob t 1972 911 T |
Max Sluiter
If they are plastic throttle bodies they are not from a Porsche. The throttle bodies with the butterflies in them are Magnesium. The velocity stacks were done in both Magnesium and in plastic.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Speed Dog's Chauffeur
try this guy MFIWERKS
QUOTE: Flieger If they are plastic throttle bodies they are not from a Porsche. The throttle bodies with the butterflies in them are Magnesium. The velocity stacks were done in both Magnesium and in plastic.
Go to someone who builds & tunes MFI for a living to get advice not the posters!!! Go to an MFI shop or someone like Mark who runs outlaw racing MFI motors out of his shop so they may be able to actually help you with your issue. Mark actually runs some built late model motors with MFI(not easy to tune). Racers generally know how to fix things. Mark's biz is MFI so check the posts for feedback. I ran MFI for some years so I know it is not a picnic of instant opinions/posts. Better research = better results. Good luck. ![]() Mark Jung Seal Rock, OR mfiwerks.com |
Max Sluiter
Maybe some aftermarket company has made plastic throttle bodies but unless they are carbon fiber reinforced plastic I wouldn't want them. The Magnesium ones wear out bad enough.
Aha, free advice being offered, or maybe not. The throttle body screw adjusters often do break as you get a electrochemical reaction between the steel adjuster screws and the magnesium body material. You need to be uber careful to release the lock nut and then if the screw is frozen work very carefully to loosen the screw using heat and the usual methods to avoid a broken housing. I tried a dental compound to repair one broken adjuster mount but it broke after about 6 months so I ended up with new/old throttle bodies. Maybe a skilled welder could work with the magnesium, but if the throttle body butterfly spindles are worn as well then good replacements are a better option. Good luck with that.
1972 911T Coupe with a '73E MFI engine and 'S' pistons 10 year resto mostly completed, in original Albert Blue. ***If only I didn't know now what I didn't know then*** |
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Now it looks like some positive direction
Bthibo
Thanks for info and suggestions on my problem. After further checking the body is Magnesium, so I decided to just order a used body instead of repairing.
bob t 1972 911 T |
Max Sluiter
Magnesium can definitely be repaired. Perhaps you can exchange your cores for a new rebuilt setup from Eurometrix? (They are the guys I think of first when I think MFI throttle bodies. Mark Jung is great for the MFI pumps).
Keep it on the shelf
