Fuses on 1973.5 911 ?
Can anybody verify if this is correct for a 1973+1/2 car?
Discovered the painter had lost a few fuses.... Top Fuse Box Fuse (amp) Circuit 1 5 – Yellow luggage/glove box light, interior light, clock 2 16 - Red warning light 3 25 - Blue window opener 4 16 – Red cigarette lighter (aux. heater) 5 16 - Red sunroof, (rear window wiper) 6 25 - Blue windshield wipers, windshield washer motor 7 25 - Blue fresh air blower, rear window defroster 8 16 - Red stop, turn signal & backup light 9 5 – Yellow front L. blinker light 10 5 – Yellow front R. blinker light Bottom Fuse Box Fuse (amp) Circuit 1 8 - Red L. high beam 2 8 – Red R. high beam 3 8 – Red L. low beam 4 8 - Red R. low beam 5 5 – Yellow L. parking light 6 5 – Yellow R. parking light 7 5 - Yellow license plate light 8 16 - Red (fog light) Rear Fuse Panel Fuse (amp) Circuit 3 5 - Yellow 2 8 - Red 1 25 - Blue MSD Ignition box – bottom fuse White = 8 amp fuses Red = 16 amp Blue = 25 amp
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Randy,
From the spec book:
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
lol..was about to reply when i see that warren has beaten me to the punch..and i'd say it's a 'safe bet' (read 'sure thing') that he's in the ballpark..whaddaya say, randy?
![]() ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
Dang! Breathing the paint body filler dust must have given me dementia - I have a flippin' spec book but didn't look.
Thanks.
Maybe this is an appropriate place to ask a fuse question. When I recently installed my Sucro relays I became aware of how aged my fuses had become on my '76. Although they all function, the filaments are nearly black and many are stuck to the terminals and had to be peeled off, ripping some. Should they all be replaced? Are the Buss glass replacements recommended rather than the Bosch exposed filament type?
Howard '76 911S '53 Nash (!) '01 Audi TT '82 GPZ-550 |
To data to this 1973.5T fuse thread; labels from the front fuse covers:
Thanks, Jim -- too bad there aren't repro's of those labels...
Howard, there were earlier threads on the old fuses. I'd replace all of them. Also, you can clean the contacts with chemicals made by Caig or others - go to an electronics supply store and talk to them. You might need fine emory paper on some of the contacts. Some people have tossed the whole thing and gone to modern fuse blocks that use the blade type fuses that new cars use.
Randy
I took some photos of the original fuse box on my '73.5 as part of my RSR clone conversion. I found them helpful along with the wiring diagram. Hope they will help you as well.
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
1-6-2-4-3-5-1-6-2-4-3-...
'70 911E Coupe, Webers 40IDA |
Do standard glass fuses work to replace these?
The "standard" glass fuses will not fit the electrical connections on the fuse box poles.
You need to used the bullet type fuse Pelican Parts - Automotive Parts and Accessories - Porsche & BMW
Replacement fuse panels
If someone can give me an accurate measurement between the top and bottom mounting holes for the 1973/1973 1/2 fuse panels, I will attempt to build an ATO
style panel for these cars. From the pictures, it appears that the mounting screws are located between the fuse mounts which will make it a bit tight to get more than 18 fuses on the new panel. However, with the measurements, I will see what I can do. I have had a number of inquiries about panels for these cars, but have not had access to one to get the info.
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Hmm... I'm guessing local stores don't sell these. My cigarrette lighter died... need to check the fuse among other things. Guess I can just get an inline fuse holder as an interim solution.
My local NAPA has them.
![]() Fuse box mounting tabs accept speed nuts, so there is some room for adjustment. The 4 holes on the left are for the relay mountings. BTW, these mountings should work for all 911 from '69 through '73. |
Measurements
Thanks, I should be able to work up a panel for these cars now!
