Start and drive.........
Warren,
Could you start and drive the car right away from a cold start? Or had to wait a few minutes before taking off? Keep us posted.
Tony
Old 11-30-2012, 10:10 AM
wolds's Avatar
Tony,
I haven't driven the car with the new CCP setting, I'll do that tonight. With the old setting though you could drive off without an issue. The problem was (see my initial post) was that at 50 degrees ambient the engine had to crank for a longer period of time then I thought it should, but at 28 degrees ambient it would pretty much catch right off. I also noticed that I had an initial lope at idle for a few minutes, but would go away as the WUR was transitioning fromm CCP to WCP maybe 2-3 minutes. All what I'm trying to do here is get the car to light off a little quicker then it was doing at 50 degrees ambient. Make sense?
Warren
Lorraine 83 SC CAB RoW
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 11-30-2012, 10:21 AM
wolds's Avatar
All,
OK, so I drove the car tonight and she fired up well and I was able to pull out of the garage without any gas pedal feathering or stumbling of the motor so I think for now I will just "leave it alone". Here were my final test numbers.
ambient temp: 13C
CCP vacuum on: 1.6bar
WCP vacuum on: 3.5bar
System pressure: 4.8bar
Time to transition from CCP to WCP: 4:00 minutes
Residual pressure after 1 hour: 1.5bar
Thanks for all your help on this one.
Warren
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 11-30-2012, 03:06 PM
