1990 911 stuck in reverse
Please hit me with some ideas.
I backed out of a parking stall and when I shifted in 1st gear and let the clutch out it killed the engine. Even in neutral the transmission is stuck in reverse. I'm thinking the shift fork may have sheered it's roll pin, is that a possibility? |
I've been reading about the reverse light switch. I think I will start there.
Rescuer of old cars
A 1990 911 has a G50 transmission. I doubt that it is the same situation as in the earlier 915s, which is the ones with the pin under the reverse light switch.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
PhD on Pending Projects
Welcome to the club... I have a 1991 C4 Cabriolet that suffered the same problem. One day I was driving normally to work and when I got out to head back home I could not shift it.... Lucky for me, it got stock in second and I was able to drive it home. I thought it was the bushings on the shift linkage but not the problem... Car is parked until I have time to drop engine and tranny to check in more detail. Let us know what you find.
Here is my post when it happened: Shift linkage bushing - Rennlist Discussion Forums
Drive safe! 1967 - Porsche 912 1981 - Porsche 911 SC 1991 - Porsche 911 C4 Wide-body Cabriolet |
Sorry, did not mean to scare you... could be as easy as the bushings going bad. Here is what I did to a friends car that was having problems shifting into reverse... hope is as simply as buying the bushings from our host, replacing those, and getting the car back on the road. Thread was from 2009...
Wow... that was when I had the mid-rise lift...
While in there, replaced both shift linkage ball cup bushings, part #928-116-145-03, available from our host (Pelican). Here are more old post from when I was troubleshooting my '91
Fleabit peanut monkey
Read up on the transmission reverse detent. I read my old receipts and talked to all the previous owners and one of the physicians that owned it said it got stuck and he had to drive backwards for four miles.
Had to pull trans - I hope I remember that correctly. Was nowhere rebuild cost but there is labor with pulling it.
1981 911SC Targa |
Is that specific to the 915 transmissions? or G50 suffer from that as well? In my case it is not stock in reverse... only goes into 2nd and 4th, with lots of effort... Anyway... did not mean to hijack the thread. Back to normal programming.
Maybe the transmission removal I was thinking of was just simply "Porsche tax" from having the repair done at the dealer and the cost was several hundred dollars for replacing the pin and switch. Don't know for sure. Would have to re-visit the receipts.
1981 911SC Targa |
| Tags |
| 915 , transmission |
