French Import
zippy_gg's Avatar
Carrera Rear Caliper Piston Question
Rebuilding the rear calipers of my 86 Carrera while the suspension and engine/tranny are out.
On the passenger side all went well with the removal of the pistons. The driver was another story and I had to pry them out after failing with compressed air. I tried pushing them back in with a C-clamp and prying them out several time, adding PB Blaster when the pistons were partially out.
Alas I broke off part of the ledge that holds the seal on each piston...
Sorry for the crappy pics from my iPhone...
Is it OK to replace the pistons on one caliper and not the other?
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 12-02-2012, 06:26 PM
Senior Advisor
James Brown's Avatar
yes, good time to get them stainless steel ones for the next time
08 Cayenne Turbo
Old 12-02-2012, 06:32 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Damn Zippy,
Next time use your brake lines
'85 Carrera Targa
PCA/POC
Old 12-02-2012, 06:39 PM
French Import
zippy_gg's Avatar
Originally Posted by DRACO A5OG View Post
Damn Zippy,
The calipers have been removed for a while.
The pistons would not come out past a certain point; there was a bit of rust on them...
Gilles & Kathy
Old 12-02-2012, 06:58 PM
cashman's Avatar
Stupid question, how do you prevent brake fluid from getting everywhere when using your brake line when the piston pops out? I used air last time I did it.
1989 911 Carrera Cab
25th Anniversary Edition
Euro Pre-Muffler, SW Chip
There's nothing better than: Listening to "Going Down the Road Feeling Bad" ,as I, "Go Down the Road Feeling Bad"
DRACO A5OG's Avatar
Oh damn, call me next time, so we can have two brains on it , man sorry to read your troubles.
Not stupid, a fellow pelican came over with his stuck calipers and we used my car to pop them out, He also failed with air. No biggy, I just pressed the brakes 2 inches and locked them in place, removed the brake line and placed it on his and then I pressed the pedal down, "pop" it came right out.
Yeah, you need a fool like me to do that but if all else fails???
'85 Carrera Targa
PCA/POC
Old 12-02-2012, 08:31 PM
French Import
zippy_gg's Avatar
Bad news... PP does not carry Carrera caliper pistons...
I e-mailed PMB and hope they have some.
Gilles & Kathy
Old 12-03-2012, 07:47 PM
