Spacer removal
I want to adjust my E-brake on the rear wheels (77 wide body) however, I have spacers on them.
How do I go about removing the spacers so that I can get to the emergency brakes star adjustment etc?
Was looking for a thread but could not fine one.
Is there any special tools I need for this task?
Old 12-03-2012, 09:51 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Have you taken the wheel off and looked at the spacer yourself?
1981 911SC Targa
Old 12-04-2012, 12:46 PM
cycling has-been
bkreigsr's Avatar
if it's stuck to the rotor, tap with a rubber mallet it while rotating the wheel. repeat as necessary, upgrading the rubber mallet as you go.
Bill K
Old 12-04-2012, 12:53 PM
Bob Kontak's Avatar
Upgrade to lead.
1981 911SC Targa
Old 12-04-2012, 01:10 PM
cycling has-been
bkreigsr's Avatar
Originally Posted by Bob Kontak View Post
Upgrade to lead.
....if you want to mess up the aluminum spacer
Old 12-04-2012, 01:37 PM
safe's Avatar
Rubber is useless, it just bounces and will hit the fender or the face... without transferring much energy to the object you are hitting.
Use a plastic mallet that is filled with steel pellets.
If the spacer is a "bolt on" spacer: After you remove the wheel have someone press the brake pedal to lock the wheel.
Magnus
Old 12-05-2012, 06:43 AM
RETIRED
Joe Bob's Avatar
A spritz around the edges with PB Blaster or equivalent and a whack with a dead blow hammer.
Maui...you have a PM, I have the Bentley open and can prep you on the adjustment.
2012 ML350 3.0 Turbo Diesel
Old 12-05-2012, 07:56 AM
Huh?
Did someone recommending throwing the rubber mallet at the spacer? - you're supposed to hold on to it.
(it should just take a couple of light wacks to free it from the rotor)
Bob S
Old 12-05-2012, 08:16 AM
I've never had a problem with using a rubber mallet. Although a dead blow hammer works just fine too.
Old 12-05-2012, 08:23 AM
Bob Kontak's Avatar
Using lead, I agree if you hit it with swinging blows. Deal is delivering impact and lead will do that nicely with a firm tap.
1981 911SC Targa
Old 12-05-2012, 02:16 PM
PB (great stuff) and a rubber mallet sound like the way to go.
Old 12-06-2012, 10:01 PM
