Identify this CV boot and joint model and year
Gents I need to identify this CV joint and boot any suggestions ?(the answer won't be complicated its just my lack of knowledge holding me back)
Flanges are 75 911S 4 bolt 2 dowel 108 mm diameter. Shafts are original 75S.Joints are 108 mm diameter and 32 mm thick originally 6 bolt but have a spacer fitted under the mild steel cover which blanks two of the bolt holes which are now used for dowels.
Thanks in advance
Andy
Old 12-06-2012, 01:42 PM
kodioneill's Avatar
Seems to me you answered your own question!
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 12-06-2012, 03:03 PM
Gents, I really do have a problem getting the new boot to fit one of these CV's the 75 one supplied doesn't fit I returned it and have been sent another which also doesn't fit. Can I take it these are recognisable as 75 standard fitting and its my supplier who keeps sending the wrong part ?
Andy
Old 12-07-2012, 06:19 AM
kodioneill's Avatar
If you mean it doesn't fit the flange try using a hair drier or something to heat the rubber up then slip it over the lip.
1982 chiffon 911sc
Old 12-07-2012, 07:20 AM
they have to be stretched to fit.
206 637 4071
Old 12-07-2012, 07:22 AM
Thanks guys, but the boot being supplied to replace one I damaged when assembling the sahfts into the car literally does not fit. I've done loads of these in the past on a variety of cars. However I think I've solved the problem by buying a boot and tin flange direct from interparts using their part number...deal cheaper than the OEM or porsche specific aftermarket price too. Time will tell.
Thanks again
Old 12-07-2012, 07:56 AM
